0 members (),
329
41
Posts837,992
Posts: 175 |
Where can I get the chrome trim from around the headlight? I have looked at many online and even purchased a pair but they are not the same fitting. The inside edge on the morgan ones are flat with a type of bayonet fitting and sort of twist on before being secured with a screw. The ones on sale seem to be round on the inside edge and these don't secure properly. I have looked at the ones on Melvyn Rutters but thy do not look to have the flat edge. Any ideas of best place to secure a pair? What car were these originally from? Mine are on a plus 4 2014. ( or the remaining one is as one has fallen off somewhere).
Thanks for any assistance.
Andy 2014 Morgan Plus 4 VW T6.1 campervan
Posts: 27,835 Likes: 761
Posts: 27,835 Likes: 761 |
A morgan dealer or ebay. They were off land rovers and old minis
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Quality is questionable these days, and there are two depths. My 2016 has the deeper profile. Stainless are also available.
Fitting is hit and miss, and it helps to add some neoprene profile around the inside which makes the fit tighter, and also reduces the whistle......................
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Mine were stainless ex factory in 2018 as was the strip of neoprene stuck to the headlamp frame.
Ihave a genuine morgan spares one at home for a 2014 Roadster. Where are you based if you use Uncle Melvyn?
Posts: 175 |
Ihave a genuine morgan spares one at home for a 2014 Roadster. Where are you based if you use Uncle Melvyn? Thanks for the offer John but I am in Cheshire. I will order some Land Rover ones and see how I get on.
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
Andy, lots of options here & if they (surprisingly) won't fit, Mini Spares are good at taking stuff back https://www.minispares.com/search/classic/headlamp%20rims%20.aspx
