Topics49,838
Posts837,293
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Clemens I trust you didn't make your good lady feel guilty with you being forced to take your Plus Four  Sie müssen eine Kiste Bier holen  Gott sei Dank - kein wasser...bitte.. Sprüdel oder non-Sprüdel? Ich Denke bides. Blay und grun als stopfer Stimmt. Beides 👌 Richard bei mir geht das Bier nie aus … beim Wasser kann das schon mal passieren 😂
Clemens
PlusFour Red Baron MY 2022
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Clemens I trust you didn't make your good lady feel guilty with you being forced to take your Plus Four  Sie müssen eine Kiste Bier holen  Gott sei Dank - kein wasser...bitte.. Sprüdel oder non-Sprüdel? Ich Denke bides. Blay und grun als stopfer Stimmt. Beides 👌 Richard bei mir geht das Bier nie aus … beim Wasser kann das schon mal passieren 😂 Schön zu hören Clemens
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Good to see my fat fingers murdered my bad Germen.
A cold dark damp day here in Suffolk at around 9c. I went to lunch in Lavenham with 3 TMers so took the CX. I really enjoyed the drive though MMC it seems still can't provide instruments that don't fog up. ![[Linked Image]](https://tm-img.com/images/2024/12/17/20241217_115049.jpg) I have also bought a bluetooth remote control to control music , radio etc off fleabay. It works well. I chose the location under the dash roll top, as opposed to on the wheel, as I don't think it is waterproof. ![[Linked Image]](https://tm-img.com/images/2024/12/17/20241217_150330.jpg)
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
They all do that Sir.
I've tried everything....plastic coating on the front of each small gauge, multiple holes, leather coat, nothing works.
All of mine (all 5) have had this feature to a greater or lesser extent. Today was also extreme humidity (>90%) and cold. When I first sat in the car in the garage the windscreen & side screens instantly misted.
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
The car is getting more use as the odo-meter would suggest. But all short drives in the neighbourhood. A transfer to our place in Italy was cancelled due to health issues. But I really hope to get it there in spring and set up a meet with Gambalunga once the snow vanisches off the Stelvio pass (we live on opposite sides). with friends (Jag is sold though and the Boxster is now a 991T) ![[Linked Image]](https://www.tm-img.com/images/2024/12/17/IMG_3384.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2024/12/17/IMG_3247.md.jpg) ![[Linked Image]](https://www.tm-img.com/images/2024/12/17/mog.md.jpg)
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
1560's photos ![[Linked Image]](https://www.tm-img.com/images/2024/12/17/IMG_3247.jpg) ![[Linked Image]](https://www.tm-img.com/images/2024/12/17/IMG_3384.jpg) ![[Linked Image]](https://www.tm-img.com/images/2024/12/17/mog.jpg) Steven you need the full BBcode for them to show.
1 member likes this:
1560 |
Posts: 65 Likes: 17
Posts: 65 Likes: 17 |
Took my Plus Four for a nice Cotswolds run for a couple of hours at 6 degrees C. New experience: driving in thick mist with the roof off, the inside of the window (and the rear vision mirror) was soon coated in crud. Seems to come in with the moisture. Dashboard needs a clean too now. The outside was OK thanks to the comedy windscreen wipers doing their bit.
Out again in the morning - even colder forecast - this time I think I will stop every 20 mins and clean both sides of the windscreen!
Given the weather improved from fog to sun today Hawki and I nipped out to Manningtree for a coffee .Great fun. The stereo worked well so I am a happy lad. ![[Linked Image]](https://www.tm-img.com/images/2024/12/30/1000009059.jpg)
