6 members (Rex_tulips, AZJowett, Rog G, Ian Wegg, Barry13, Mike D), 308 guests, and 39 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,335
Members9,215
Page 2 of 137 1 2 3 4 136 137
Originally Posted by TBM
...Been soaking regularly in plusgas and will attempt a removal over the weekend. Get ready for an enormous amount of swearing, and bracing myself for a head removal and some helicoils....
Do you have PB Blaster products on your side of the pond? They have a penetrating catalyst that works amazingly well.
Originally Posted by M3W55
110 miles on better roads from St George-de-Didonne to Cadillac, taking the ferry from Royon early
This should actually be posted in the "So Have You Driven Your Morgan Today?" thread. I started this one more for maintenance or improvement projects.
Great photos, thank you
Quite right - I misread the thread title.
TBM Offline
I'm not sure, I'll have a look - thenk you for the recommendation.
I was having a closer look at the studs yesterday, and at least four of the five remaining studs have a thread or two showing beyond the 'raised section' on the engine side. When trying a last tighten I was getting a real 'creak' from the bolts. This suggests to me that the nut was tight on the shoulder and I was actually moving the studs.. The implication is that a) there is movement in the studs (wishful thinking) and that b) this may be why the manifold was not sealing effectively.
Last couple of days I've been trying to treat the rust patches on my wings.A horrible job as the wing edges contained an enormous amount of filler and I've had to try and recreate the original profile using more filler. Not perfect but a reasonable job and no worse than the previous restorer. Also whipped off the manifold as the exhaust was blowing a little at the block. Got new gaskets on the way, but not looking forward to trying to remove the old studs.. Been soaking regularly in plusgas and will attempt a removal over the weekend. Get ready for an enormous amount of swearing, and bracing myself for a head removal and some helicoils....
Piece of piss to take a cylinder head off a crossflow!
I helicoil the exhaust stud threads on my heads as a matter of course. I use M8 stainless grub screws with a small hex in the end - use a small hex key to stop the stud turning when tightening everything up.
Arwyn
Day off yesterday so spend most of it in the workshop.
Machined up a pair of kingpins for my 1933 JAP Super Sports, machining the top collars from an old 4 wheeler King pin.
Went to braze them up and then ran out of acetylene
Made up a rear wheel spindle for the same car out of better spec steel (EN19T), old one was worn and bent into an 's' shape
Made up a rear spindle nut in stainless for the three wheeler and silver soldered the oil seal carrier/rear wheel spacer back together
Got a phone call from my pal to say the chassis was ready for collection so drove up to Leyland in Lancashire to pick it up , just about fitted in my Golf estate.
Came back, tidied up the workshop ready for Plus 4 coming back from trimmers on Sunday, cleaned and oiled the lathe and vertical mill.
Set a few jobs up for Saturday then locked up!
Arwyn
TBM Offline
Arwyn
Agreed - I reckon I can do it quicker than trying to change the fan belt on my Corsa.......
The replacement studs I have are the same style, although 5/16" UNC
Arwyn
Bloody hell Arwyn - You could have called for a brew!
Ian S
2019 Sports Green Plus 4
2025 Hyper Blue Mercedes 180 CLA
Be wary of using Stainless studs, their tensile strength is not great and I believe can react with ali. When I did mine on my 911, I went with Titanium studs - god they are a sexy item !!!
