8 members (Whizjet, Julian BB, JohnHarris, Wouter, B3MOG, bmgermany, John Winn, Graham, G4FUJ),
155
38
Topics49,901
Posts838,042
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
I have already had a few problems with my PlusFour. However, I have never had a misted-up instrument.
Clemens
PlusFour Red Baron MY 2022
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
It is a feature mine has. The UK coastal area has a lot of humidity
Posts: 37,481 Likes: 989
Posts: 37,481 Likes: 989 |
Iām really interested as obviously we are true coastal but neither Plus 8 VDO gauges misted but the 4/4 Sport got misted up unless on a long overnight trip so I assume the internal lights provided a source of heat to overcome the temperature differential.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Having the lights on initially make mine steam up more, I suppose because it increases the temp difference. Once back in the garage they will demist really quickly, so it's very dependant on the outside temp.
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
Yes Dave you need a series Land Rover with Smiths round fug stirrer to fully demonstrate the physical effects you describe
1 member likes this:
DaveW |
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Possibly caused by not being automatically light up unless the lights are turned on and they don't have incandescent bulbs that would raise the temp and dry them out. My tin tops have dash lights automatically and they are incandescent and don't mist up.
Posts: 3,876 Likes: 402
Posts: 3,876 Likes: 402 |
I was out for a good hour run this morning roof off about 8c but dry with clearish skies no warming heat from the sun, the heater was set to max heat but the blower was off, the one dial for water oil and fuel only misted up in the last 10 minutes or so of the journey only the oil and water sections misted up not the fuel, they are at the lowest level . The car had been in a cold garage for about a fortnight under a cover. I presume they are all electrical feeds to the dial in question..
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 1,412 Likes: 259
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,412 Likes: 259 |
They all do it. First world problem. One of the many quirks/features/idiosyncrasies of a Morgan It is what it is....... šššš¬š§
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
They all do it. First world problem. One of the many quirks/features/idiosyncrasies of a Morgan It is what it is....... šššš¬š§ Yep. We drive these things because we love them, not because they are actually any good by modern standards.
I don't think I've ever experienced 'Modern standards'.
