0 members (), 293 guests, and 34 robots.
+8Rich 93
Posts837,277
Page 14 of 15 1 2 12 13 14 15
Rog #795338 05/02/24 04:57 PM
Rog Offline OP
Thanks Richard, and yes pins 3 & 4 of the relay assembly connector go off to the spot switch on the dash.
Roger
Rog #795394 06/02/24 05:25 PM
Originally Posted by gomog
May I prepare a gomog article for your consideration and approval?
Originally Posted by Rog
Thank you gomog but everything I have to offer is already here. What I've done is not a definitive solution and as said above, here the information can evolve as other contributors come and go.:
Nonetheless, Rog, IMHO, it is a great start. Once posted it will get feedback. I hope,over time, that it will become a standard trads so equipped. Let's prepare these cars for the next 100 years.
Now that traditional Morgans are no longer produced, I feel safe in opening a section for post 2003 traditional cars. No longer a moving target.
Thank you and YOU can call me Lorne. laugh2 I prefer it :cheers :
gomog #795430 07/02/24 09:12 AM
Rog Offline OP
By all means add a link to the TM thread but would prefer to keep any information in one place here. That way it can be kept accurate and updated.
Roger
Rog #796276 22/02/24 05:38 PM
Rog Offline OP
Some late info….
Should any other owner wish to use this bespoke connector in the future, the download links for the 3D print files are below.
The printed components have pilot fixing holes, intended to be drilled out/tapped M2.5
Just to refresh, it mates with the (dashboard sub harness) connector that would have originally plugged into the PCB’s 15 way header, here.
Top cover download link
Bottom cover download link
Roger
Rog #796563 27/02/24 07:32 AM
Amazing, thanks Rog thumbs
Rog #810448 27/10/24 06:40 PM
Out of interest is there a similar option for GDI +4’s?
Rog #815903 20/01/25 08:44 PM
Interesting sherlock
It seems Morgan understood there was an issue and were starting to add PCB protection, if not a fix ooo
There shouldn't be any need as all the functions of the essentially open/fragile PCB were located in a sealed BCU (body control unit) on Plus 4 GDI and 3.7 Roadster. This unit in fact provided more including screen heat and floor lighting timeouts and is generally considered reliable.
I'm pleased to report the later 4/4 PCB I bought from ebay has litrally brought everything back party
Rear fog light, ignition warning light, handbrake warning light, the heater fan, and even the heated screen are back. The newer 4/4 PCBs are clearly better, well they're fuse protected at least, so if it happens again I'm only in for a £0.10p fuse rather than a discontinued PCB, or trying to solder burnt tracks.
I'm not sure when the fuse protection was added, but I can confirm the crashed 4/4 my replacement PCB came from was a 2018 model, so it's also 5 - 6 years younger than Monty's original blown board that lasted 10 years before failing, so hopefully that alone means I've bought myself some more years of trouble free electrics.
In addition to the later far younger board that's also now properly fuse protected, I decided to fit an LED bulb in the rear fog light, I bought it from Classic Car LEDs as in my experience they only sell good quality LEDs. This should pull a lot less current through the circuit compared with original incandescent bulb, the idea being it will take considerable load off the board.
Actually I bought two, one for the rear fog and one for the high level brake light as that bulb had blown, these LED bulbs from Classic Car LEDs are the red output type which work way better than white LEDs under a red lense, they're very bright so I can definitely recommend them thumbs
It was a £200 spend I wasn't planning for spend, but hopefully the younger/newer version fuse protected PCB will last? It certainly fixed absolutely everything that had gone down on Monty and came with a nice bonus too. Unexpectedly, the breaker actually sent me the whole dash with the three gauges, and even a clock. Obviously, I only needed the PCB but I now have a spare dial set too, so I now feel it was very good value and definitely money well spent!
Happy days celebrate
Rog #816763 02/02/25 08:23 PM
Good result, the spare gauges could be useful
There was someone recently with an early Roadster who posted for advice on a duff clock (running backwards), you may be able to recover some £ if he wants it ?
