Topics48,338
Posts812,950
Members9,203
Posts: 144 Likes: 2
Posts: 144 Likes: 2 |
Hi all I'm planning my first European road trip from the UK to Bologna and am going to order a rack for the rear.
I think I already have the lower attachment points next to each tailpipe, so assume I just need to order the rack itself?
I like the look of the Librands one with the storage for the side screens.
Any tips on fitting? I assume I have to peel off the Morgan badge that's on the circular spare wheel cover...? Anything else I should watch out for?
Many thanks in advance!
Heron Grey & Typhoon British Green Super 3 SOLD Plus 6, Silver and tan.
Posts: 1,700 Likes: 105
Posts: 1,700 Likes: 105 |
Hi Professor,
Check if the brackets are the updated brackets, after 2022 it should be okay, otherwise it can be necessary to have some extra weldings. Especially if you plan to carry widescreens as well as luggage on the rack. There is a thread bout it. I will search this for you!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 144 Likes: 2
Thanks for the link and advice re brackets! Mine is a 2023 car but I will double check. This is when the forum is at its best! Thanks so much for your help!
Posts: 26,747 Likes: 419
Posts: 26,747 Likes: 419 |
You need to remove the round cover. The badge is bolted on. You need a fixing kit and on here I posted how I fitted mine. See this link
Posts: 144 Likes: 2
You need to remove the round cover. The badge is bolted on. You need a fixing kit and on here I posted how I fitted mine. See this linkThats very helpful, thank you. I'll check that I get a fitting kit with the Librands rack.
