3 members (Luddite, TBM, Image),
248
80
Topics49,870
Posts837,670
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
TMers Following on from above................... My MOG has decided to not work with Main beam on, just my side lights. When i fitted my spotlights, i wired them so that the spots come on at the same time as i put on Main beam and vice versa. In the past this has been a separate rocker switch (the spotlights) but travelling at night i found a pain to go from Main beam and also use the rocker switch at the same time, so not blinding the oncoming driver. Have i done wrong? it seemed like good idea to me at the time. As i write this i haven't checked the fuse box! As normal your replies will be gratefully received! The "vice versa" part of your wiring description worries me Dave. I know you need to sort missing main beam but would re-engineer spotlights with a relay in the course of fixing this (possibly blown fuse or headlamp dipswitch issue) The relay coil (trigger) should receive power from headlamp main beam via the spotlight rocker switch. The main relay contacts should receive power from an extra fused power feed. The borrowed wiring diagram below illustrates this. The spotlight rocker switch could be fitted in series with orange cable or better still in the green coil ground lead from contact 85. ![[Linked Image]](https://www.aulro.com/afvb/images/imported/2013/11/1630.jpg) Wired this way the headlamp dip switch will not have the extra spotlight current through its contacts, neither will the rocker switch. The spotlights will only illuminate when switched on and headlamp main beam selected. You then won't get the undesirable and potentially dangerous vice versa effect.
Posts: 6,671 Likes: 438
Posts: 6,671 Likes: 438 |
TBM At work, and the boss not in, so time for a quick reply. The issue is only on full beam. Everything else works, horn and indicators working fine. . That does point to either a problem with the main beam relays/wiring or the main beam contacts on the the actual column switch itself. Good luck the investigation work.
Typically there aren't any relays for dip/main headlamp control. The only Morgan I'm aware of that does use one is the 5 speed V twin M3W. I know some have added them to save the dip/main light switch contacts but it's designed to cope so unnecessary extra complexity in my view.
Using a relay for spotlamps is advisable though, however if the car used LED's all round you could easily get away without.
Using a relay for spotlamps is advisable though, however if the car used LED's all round you could easily get away without. In a previous post Dave said he was sure he'd fitted relays when wiring in the spots. I blew my stalk switch when I originally replaced my sealed beam headlghts with halogen H4 units (no spotlights). I had to replace the switch and fitted main and dip relays. TBM Yes i'm 99% sure i put in relays. My column switch is from a Austin Mini. I will check the relay at the next chance. Many thanks for getting back to me so quick.
Posts: 12,261 Likes: 319
Posts: 12,261 Likes: 319 |
Using a relay for spotlamps is advisable though, however if the car used LED's all round you could easily get away without. True for more recent models but the older stuff had sealed-beam headlamps at something like 35W. Bunging in a pair of 55/60W halogens leads to quite an increase in current through the dipswitch which will burn them out if relays are not fitted. I learned this the hard way.
2 members like this:
Graham, G4FUJ, TBM |
Posts: 730 Likes: 58
Posts: 730 Likes: 58 |
Gents
Nothing like a good topic to get people thinking. I always find electrics a 'Dark Art'. It will be interesting to find the cause. I will update when i get to a solution.
In the mean time thank you for your suggestions. Just to let you all know I have put in LED for Side, Indicators and rear brake lights.
Navy Dave 1976 Morgan 4/4
Gents, just an update. The problem i had was caused my one of the wires leading to the relay coming away from the female fixture. Next problem, sorting out my LED indicators!
Gents, just an update. The problem i had was caused my one of the wires leading to the relay coming away from the female fixture. Next problem, sorting out my LED indicators! Good news! What's wrong with the indicators? Are they fast flashing? If so, need an electronic flasher unit - easy replace, just make sure you get like for like (2 or 3 pin usually)
TBM Sometimes they work, sometimes not. My bet is on a faulty connector.
TBM Sometimes they work, sometimes not. My bet is on a faulty connector. Is it side specific or affects both sides? When the stalk switch fails do the Hazards still work? The feed for the indicators goes through the Hazard light switch - often, due to lack of use, the feed through the switch fails. Next time the indicators work, give the Hazard Switch a few clicks on and off and see what happens.
