7 members (sezznowt, Tresco, DCH, JMcL, dakri, James B W, Willowgreen320), 263 guests, and 73 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,760
#814143 22/12/24 04:13 PM
Bunny Offline OP
This speed sensor is a direct replacement for MMC part numbers E340022 & E340110 as fitted to the M3W (2012 – 2020) which appear to have been discontinued by MMC.
It uses the same components as the original so is a direct swap. It comes with a replacement stainless steel mounting screw and shake-proof washer.
The clearance between the sensor head and the trigger should be in the region of 0.3mm to 2.3mm. Some cars do not have enough clearance so I’m including a spacer washer to slightly increase the clearance if necessary.
The price for this sensor kit is £70 including UK postage, which is around a 30% discount compared to the MMC price.
Also available is a ‘long-lead’ version which has a 1 metre lead that allows the connector to be relocated inboard (just in front of the oil tank) thus avoiding the majority of water & road dirt that otherwise could hit the connector. Looks neater too!
The price for the long-lead version is £90
Please see this THREAD which contains some more detail.
Please note that these are NOT compatible with E221002 as fitted to a few late production cars. This later type can be identified by the fact that they don't have a flying lead, the vehicle loom plugging directly into the sensor body.
Andy
Bunny Offline OP
Just an update that I now have a few of the long-lead speed sensors available for immediate despatch! These have a 1m long lead that allows the connector to be relocated from one of the most exposed regions of the car to the relatively dry area in front of the oil tank.
Comprehensive installation kit with instructions.
Also, a shameless plug for the other sensors that I have available! All are available on eBay.
Andy
