6 members (lord-richfield, Topline123, John07, mph, MartinB60, CooperMan), 289 guests, and 40 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,342
Members9,215
Page 14 of 14 1 2 12 13 14
Black Rat
Black Rat
So do I.
Keith
2013 narrow bodied + 4 Ruby.
Engine was stinkin hot, my trusted mechanic treated it like ... no help.
He says the catalyst is damaged, but I only drove 7.000km since the upgrade was done.
I will check on the upstream lambda sensor though!
The question is what kind of cat the Clubsport update has. My 2010 Plus4 Supersport had a 200-cell metal cat from the factory only and, what's more, it was much too small than to cope a 2 litres engine. It could never meet the emissions standard. My 4/4 from 2014 has a 300-cell metal cat for 2 litres engines from Brain, an HJS brand from Italy even if my engine only has 1.6 litres. It passes the TÜV for Euro 5.
No better with upstream sensor unplugged - I now wrapped the cat and hope that this will suffice. Will report again in two weeks!
Passed the MOT ("Hauptuntersuchung") with the wrapped catalyst. My assessment: if you don't run the car (and its catalyst) on a track, you will probably not reach a sufficient temperature in the catalyst for it to work properly. I therefore recommend wrapping it for "normal" road use. However, at the beginning of the test, the not so hot catalyst "produced" CO2 that was through the roof. It took a few rev-ups until they came down sufficiently. The engine idle was still not perfect, but better than before - and it passed the test.
Robert, many thanks for taking the time to share your experiences.
Interesting theory of wrapping the cat to increase it`s temperature, which in your case Robert apparently assisted in passing the required emissions testing following previous failures.
I lack any real knowledge on emissions or their testing, but suspect that cats were designed to cut down aspects of emissions from the average usage of ICE across the population as a whole, thus I also suspect that track day usage and the likes may not have been considered by Morgan and other designers, when emission measurement test data was compiled to create acceptable measurable limits being agreed upon during the lifetime of ICE average usage..?
On the other hand given I suspect that ICE machines were designed to operate within reasonable expectations of average usage. That typed, I suspect Morgans and other modern-day potential Classics fitted with cats as the result of regulatory evolution, may not in the main(?) experience usage as might the average ICE, with perhaps many likely to be rarely used dependant on seasons of the year or weather conditions in general, thus all the more usual issues of vehicles likely laid-up for extended periods of time may suffer in all the usual ways dependant on circumstances...? That perhaps being the case, I suspect those with a mix of both cats and irregular usage, might benefit from wrapping the cat to raise it`s internal temp by some measure, perhaps, and thus increase it`s efficiency by some margin for/during the tests as you seem to have proved....? thumbs
