0 members (),
266
40
New
Topics48,365
Posts813,354
Members9,215
Posts: 97 Likes: 8
Posts: 97 Likes: 8 |
Thank you RichardV6 for the excellent description. You gave me the courage to try it as well and I succeeded! Symptom was that I could not toggle between high beam and dipped beam. It just went dark instead. Failure after 30000km. Trad Plus4 2019. I managed to access the copper strip for the horn without removing the steering wheel. Replacement part for the light stalk is a Lucas OEM STC4017 from www.landy-scheune.de 1000015739 by Werni Wehrli, auf Flickr BTW the copper horn strip can be ordered as a Honda Civic 1987-1992 part 35259-SH3-A02 (Made in Japan)
Plus 4 110 Edition 2019
Posts: 7,943 Likes: 218
Posts: 7,943 Likes: 218 |
Glad it went well for you Werni. Good info on source of horn pickup brass strip as well if you can't re-use previous
Posts: 2,064 Likes: 57
Posts: 2,064 Likes: 57 |
Werni
Thank you for the info about the copper horn strip!
I had to surch a long time for a preused one....
Posts: 1,028 Likes: 15
Posts: 1,028 Likes: 15 |
in cause of non-working driving lights I‘m affraid, the MOG needs a new stalk.
So I have a look around about the STC4017 switch. There are LUCAS and BRITPART available, there is a massive difference in the pricetag. Is there also a difference in quality?
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 5,232 Likes: 125
Posts: 5,232 Likes: 125 |
I used a BritPart window motor on my Discovery 4 and had no problems. However, a window motor is fitted out of sight - I cannot comment on the finish on a BritPart stalk.
Looking on Land-Rover forums, there seem to be as many negative comments on Lucas as there are on BritPart.
Posts: 6,061 Likes: 160
Posts: 6,061 Likes: 160 |
I used to be quite heavily involved in the LR scene, and BRITPART was often referred to as SH*TPART.
However, many dealers I spoke to rated them highly - they said that due to the enormous amount of stuff they produced and shifted, even a 99.99% success rate would still result in a considerable number of problems.
My rule of thumb was if it was a relatively easy and quick to fix/replace then go for Britpart. If it took several hours to fit, then I'd go for a more expensive alternative.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
My rule of thumb was if it was a relatively easy and quick to fix/replace then go for Britpart. If it took several hours to fit, then I'd go for a more expensive alternative. Excellent strategy!
Posts: 35,791 Likes: 472
Posts: 35,791 Likes: 472 |
Rene These people have a good name too among the farming community. Including shipping to you. For comparison.
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Despite the well known name of Lucas, be careful, they actually went pop in the late 90's and were just acquired for the recognisable name and logo, most of the 'stuff' is made in the far east and some is very poor quality (like those hydraulic brake switches)
People see the familiar white & green box and subconsciously click...buy now
