3 members (Paul F, Alan Patterson, Soleng), 311 guests, and 36 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,038
Captain Morgan, IRWIN
#823138 07/05/25 07:48 PM
Ray748 Offline OP
Is it only me?I have tried to find engine oil to the spec in the PlusFour handbook but I am confused by the amount of 5w30 oils available but none as per the handbook. What is everyone else using? Thanks in advance.
I use 5W30 from Liqui Moly
Clemens
PlusFour Red Baron MY 2022
It should be API SP which was designed to reduce the chances of low speed pre-ignition - LSPI which is an issue with turbo-charged engines. Its should also have a medium ash content due to the CAT. Fully synthetic is also a requirement due to the high temps in the turbo. BMW also recommend an LL spec oil. Put all this together and you end up with Castol Edge ( the API SP version which is a later spec) or Motul 8100 eco-clean 0w-30, both of these are used by at least one dealer I spoke to. I believe the factory use a Miller oil but I dont know what the precise spec is. Frequent oil changes are probably more important that the spec as BMW have a habit of leaving the oil in too long! Good luck!
Ray748 Offline OP
Thank you guys.
Ray748 Offline OP
I cant find Castrol Edge with that spec even on the Castrol website, also loads of Liqui Moly 5w30 :-(
CRL Offline
my dealer uses Petronas. they do the correct spec.
Link for Liquid Molly 5W30 in German
Clemens
Hi, not sure where you are but I found this on Amazon - API SP etc etc
https://amzn.eu/d/1hGbtDk
The UK manual says 0w-30 - is this available in 0w?
Indeed, manual states 0W30 full synthetic.
As a retired Shell employee, I insist my dealer uses Shell oil… point is that the oil meets the proper requirements.
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
