1 members (MartO),
409
42
Topics49,841
Posts837,323
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
It looks like cracked valve guide(s) as well. Has the exhaust valve seat come out of the head? Not a happy engine...
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Steve Late 2012 M3W
Planenut Indeed, the intake valve guide is cracked in three places. After cleaning the cylinder head, I noticed that the exhaust valve seat had moved 1 mm down the outer exhaust duct and destroyed the valve. Bitsobrits The engine was built by myself from a 117 cubic inch engine with about 500 km on it and a damaged crankshaft. I bought a new crankshaft, camshaft bearing, 618 cylinder, piston, cylinder head, large valves, lightweight rocker arms, throttle body, and everything needed to get the watts. Don't ask me who made the valve spring retainers and who installed the valve seats in the cylinder head foundry. All I can say is that the valves are of good quality, judging by the results. A few moments before, it was very quickly reaching 6500 rpm in fifth gear. ![[Linked Image]](https://i.ibb.co/SwQygQkQ/20250507-195704.jpg)
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
6500 rpm..... that may be why it went pop? I know it probably can do that, the drag racing X-Wedge engines certainly did but maybe not ideal to do it, unless you are planning frequent "drag racing" rebuilds. Can't you just do some startling performance up to about 5500 rpm and save a lot on rebuilds?
The cylinder height was limited because the pistons have no carbon deposits as they are very close to the cylinder heads, the crankshaft with its grooves is generally like new.
I went to see an engine reconditioning specialist to show him my valve seat problem he told me that the problem was a lack of tightening of the valve seat in the cylinder head and that apparently the valve seats were not fitted in the correct order, the correct order is to machine first to insert the intake valve seat after machining for the exhaust seat by biting slightly into the intake seat, apparently the one who did for S&S worked in reverse order, so I will extract the valve seat to have metal replaced with laser welding then he will machine the seat housing by making the reverse embedding in the intake seat. https://ibb.co/XfYkW8QKhttps://ibb.co/4Zk2h0mX
