6 members (TalkMorgan, +8Rich, JoeSpeetjens, TBM, cerealsurfer, Graham, G4FUJ),
248
115
Topics49,872
Posts837,704
Posts: 1,019 Likes: 120
Posts: 1,019 Likes: 120 |
If the spay patterns all look the same then the basic injector function is looking good the only other check on that is a timed volume delivery.
Posts: 8 |
I’m not sure this engine has a carbon canister unless you can point me in the right direction for it. I have changed all the vac hose and can feel pressure at the ecu, so I don’t think it that. I could possibly blow an air line from where the ecu is (no on to the ecu) to check it’s clear…
Posts: 8 |
I think this is where I’m headed. Even if it’s not that we don’t plan to sell the car.
Posts: 8 |
I have been thinking it is surely more likely a device, but I have replaces lots of sensors now. Another on I need to check is if there is a switch on the throttle, but I think it’s just the position sensor and that checked out ok. :-(
Posts: 8 |
In case anyone is looking at this in the future we eventually resolved the issue with a new wiring loom! So not entirely sure where the issue was but it was an electrical fault.
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
thanks for letting us know Ben, very impressed by the comprehensive list of checks you did.
1993 T16 +4 Lancia Blue.
Fairly sure there has been a resent post on similar issue and it turned out to be the ECU. He sent it off for repair and assessment and it came back fixed for a very good price!
Hopefully someone will respond with that info.
Posts: 9 |
Hi, I had same problems with my 1991 +4M16 engine ,at the end t was the idling air stepper motor sitting on top of the throttle, put it out placed in a standard and spray some WD40 on top for several days, put it in again and idling again at 750-800Rpm. Best regards, Bart Bonnaerens/Belgium
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Hi Ben, I am glad that you found the answer: my own guess was that it was electrical due to me experiencing a not entirely dissimilar problem years ago with an M16 Plus4 which turned out to be the alternator which and the end of the long list I decided to replace. The engine was sometimes hard to start but would then run well until 4000 rpm when it would cut out and idle for a few minutes. If anyone else comes across this problem, the altenator would be one of the places to look.
Posts: 60 Likes: 2
Posts: 60 Likes: 2 |
just another point. If the car is running/moving, and as you slow down, idle drops off and the car dies, it's the speed transducer on the speedo cable! Do not buy a new one for $100.... the part is a $.10 resistor you can replace at home. In the mystery box is a resistor, magnet and a reed switch. On mine, water shorted the resistor. Simple fix discovered after I spent money on a new one. Again, it will not idle if the car is coming to a stop. The box sends an idle mixture message to the ECU. Mine's a 91 plus 4/M16.
