Topics49,866
Posts837,608
Posts: 463 |
Thanks guys, love this & I think you're right... It's your own fault, you should have had a notice up !! An update, fully checked (as best I can) the engine bay, & other than the foam I can see no damage, moved on the cockpit, again no damage, then I noticed the carpet on the rear shelf was lifted, some damage but nothing if not pointed out, so I opened the boot to find Mouse Haven... shredded micro-fibre cloth’s & a large pile of dry dog food!! To my surprise then out pop from the boot lip this little fella…. Needless to say, its now, along with a friend, a slightly different shape, the traps worked well. The dog food has now moved to a different lockup, & in a steel bin, I’ve yet to decide on a new cat……
Posts: 28,901 Likes: 352
Posts: 28,901 Likes: 352 |
Have you turned the engine over, gently? I don't think they can get near, but a pal with an old Matchless 250 found after one winter that he could not fully turn the engine over, but he can rock it, just not as far as TDC. He suspected the little blighters had been storing nuts and seeds in the combustion chamber, reached via the exhaust pipe and valve (there was no air filter damage - a non standard item). Unfortunately, he's now retired and I have not heard whether the head is off the engine yet...
Cheers,
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Cheers, On a modern car the cat should block that path to the combustion chamber.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Bud 4/4 "Stanley"
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
1972 4/4 2 Seater
Posts: 75 |
Posts: 297 |
Peanut butter at the end of a stick teatering over a bucket of water works too.
'67 +4 tourer - broken white - RHD
Posts: 297 |
Now I just feel bad after seeing Mickey and his Morgan.
Posts: 203 |
Great story , how did it get in the boot though !
Great story , how did it get in the boot though ! It probably "mouseled" its way in
Bud 4/4 "Stanley"
