Topics49,872
Posts837,695
Posts: 13 |
My 4/4 came with a non standard exhaust system and is far too noisy. Need all parts from the outlet of the 4 branch manifold - ca.45mm dia. Suggestions welcome on where to buy welcome. Thanks
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
An exhaust specialist could make one up for you and fit it to the car
Nothing too difficult about them - just a barrel silencer and tail pipe. Let me know if you need photos and or dimensions.
I had one made up a few years ago for my 1972 4/4 in 1 3/4" stainless. Silencer cost £120 and tailpipe was £65. Written lifetime guarantee as well.
Just make sure that the mounts are sound. 4/4's of that age use a single bolt bracket which works loose and causes the hole in the chassis to wear oval or a nice star crack to form. Much better to modify the exhaust mounts so you have the bracket secured to the chassis by two bolts.
Arwyn
Posts: 6,672 Likes: 438
Posts: 6,672 Likes: 438 |
Melvyn Rutter seems to do all the parts but you may need to ring/email for the full system. Librands also have some stainless options. However, both will be much more expensive than having one made up at a exhaust specialist as Arwyn suggests.
I built my own out of stainless ebay bits - mine is intentionally quite loud but could have gone for a larger silencer if needed. Cost about £80 IIRC
1 member likes this:
Snowteck |
Posts: 13 |
Thanks Arwyn, Photos and dimensions would be much appreciated. I note that the tailpipe should have an offset where it passes behind the rear wheel. Also, did you fit fit a tailpipe silencer in addition to the main silencer? Is your exhaust specialist anywhere ear the New Forest?
Greetings
As luck would have it, I'm out in the 4/4 tonight so will get some measurements and photos sorted. Can you PM over your email address and I will email them to you.
No tailpipe silencer on mine. Part of the reason I had the exhaust pipe fitted to the car was to allow adequate clearance between the tyre and chassis rail
Sadly my exhaust fabricator on Anglesey!
Kind regards
Arwyn
