3 members (MJF, sewin, KLASG), 351 guests, and 28 robots.
+8Rich 92
Topics49,838
Posts837,294
Originally Posted by ProfessorM
Thanks all, sounds like my worries about the heating elements interfering are unfounded. Good tip about removing it - can I assume that the adhesive part stays on the screen when you remove the actual unit and you just clip in/out when parked up?
That’s correct. I find that I just need to slide it on to the adhesive part - not beyond the point of the latch. That way it is easier to slide off when parking.
Costock, UK
Disco 5
1 member likes this: ProfessorM
Yes but some found it hard to separate and of course the bit on the screen shows there might be the other bit in the car.
There is another TM thread previously on this topic - https://www.talkmorgan.com/ubbthrea...ance-autoroute-toll-tag-on-cx#Post799877
Personally I did have a few problems getting it to register through the heated element of the CX windscreen but there is a 2 inch section down each side without the element and we attached it there (inside the glass just above where the passenger side windscreen wiper rests), which seems to work fine. see picture in the other thread.
Good luck!
