9 members (Sir Percival, TomS, Graham, G4FUJ, CLPlusFour, +8Rich, hugo, B3MOG, itsfrank666, dogmog), 316 guests, and 41 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,336
Members9,215
Page 1 of 4 1 2 3 4
DaveK Offline OP
Hello TMers
Just been watching a episode of 'Shed Racing' and Ivan and Suzie have been repairing/replacing the brakes on a 1960s Ferrari. One of the jobs i will be doing very soon is replacing the brake fluid in the MOG. But during the Winter i will strip down the front brakes for a good clean up. In the comments page of the video someone has stated that he uses a DOT 5 brake fluid. As it is a silicone based, it doesn't absorb water. Has anyone in TM world used this? About 5 years ago i read in Practical Classic magazine about this DOT 5 that they recommend using this (I think), alas i have lost the magazine!
Your thoughts and comments are greatly received.
Regards
Navy Dave
1976 Morgan 4/4
Personally, I stick with Dot 4. No compatibility/contamination problems and as I change it every 2 or 3 years water absorption isn't an issue.
I'm quite happy to accept that Dot 5 may be better in extremis but I've never had any problem with Dot 4 and I'm a fairly enthusiastic driver.
I changed my brake fluid earlier this year, I bought a new 4 litre container of fluid and a tester to check whether the old fluid showed any sign of contamination. Not a sign, and I tried it on an already opened bottle of fluid (although the cap was on tight) left over from the last time I flushed the brake lines. No sign of any degradation.
Agree that DOT 4 is all you need. However, in my experience, it’s the rear brake cylinders that require the maintenance attention rather than the fronts. They are prone to seizing up if the pistons are not greased under the boots. Ctek grease is ideal.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Very true, I fitted new rear brake cylinders this year after one started weeping. The old ones had lasted 15 years or so, so I wasn't complaining.
Originally Posted by DaveK
Hello TMers
Regards
DaveK, I recommend sticking to Dot4, bleeding the brakes every 2 to 3 years, and paying close attention to the rear cylinders, as they are prone to corrosion due to being factory-fitted with no packing grease. It's a job I had to do on my 2011 4/4.
I would stick to DOT4. You could be making a rod for your own back unless you replace or clean everythig thoroughly.
GoMog explains why here
2025 MG ZS EV aka Trigger
DaveK Offline OP
Hamwich, Deejay, OZ 4/4 and John V6.
Many thanks for your replies. I will stick to DOT4, As i have used in the past. Understand your point about the rear cylinders. I replaced them about 6 years ago and do regularly check them.
Regards
Navy Dave
1976 Morgan 4/4
1 member likes this: OZ 4/4
The Dot 5.1 is an improved Dot 4 that can mix with Dot 4.
Harald
IWhen I rebuilt my car. replacing the whole brake brake system 30 years I went with Dot 5 silicon.
I
t has worked perfectly, I flushed the system with new about 5 years ago, I didn;t notice any difference/
As a car I now use mostly in the summer months, with copper brake pipes and stainless hoses, the brake system hasn;t caused me a single issue since I went over to Silicon fluid.
DaveK Offline OP
I can sense a fight here, between DOT 4 verses DOT 5 😃
Navy Dave
1976 Morgan 4/4
Page 1 of 4 1 2 3 4
