12 members (Fuel.inj, Alan Patterson, nestor59310, Strathaven, nick w, 2949olivier, stumog, +8Rich, MartinB60, Guten, Graham, G4FUJ, James B W),
318
43
Posts837,279
Posts: 389 |
I use a shoe sole glue for the clutch rubber. That was month ago. Before that it felt off the pedal every few weeks. It was detached because of bad rubber quality.
BR
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Posts: 1,947 |
As I said, not really a problem. See here: MOT manual I think you can argue that a plate with holes in is an anti-slip face, so it would only be the sort of MOT place one never goes back to that argues the matter.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Mine were just fitted , not glued on for both cars. Evostick will work as it is basically rubber in s solvent
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I think my Roadster has skateboard grip tape, but I've fitted rubbers over the top. On Bumble I used a square of double sided tape which just sticks enough to hold the rubbers in place.
Posts: 413 |
I fix the rubber with 2 screws
Don't Worry, Be Happy Morgan 4/4 1985 2,0 Zetec BMW R1200 GS Triumph TR140
Posts: 4,896 |
I think my Roadster has skateboard grip tape, but I've fitted rubbers over the top. On Bumble I used a square of double sided tape which just sticks enough to hold the rubbers in place. Skate board grip tape is an excellent idea, will grip wet or dry and be better to heal and toe on those sporting occasions.
Adrian
Posts: 2 |
I was advised to fit pedal rubbers at my last MOT. The unused rubbers I already have were perished and fell off despite gluing them on so I'll be trying the skateboard tape. Thanks for the advice.
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
Skate board grip tape is an excellent idea, will grip wet or dry and be better to heal and toe on those sporting occasions.  Yep, I've used skateboard tape for yonks, I replace it every 3 years or so.
Posts: 309 Likes: 9
Posts: 309 Likes: 9 |
There's no need to overthink it. Lashings of Evostick and tread on it!
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
