Topics48,335
Posts812,890
Members9,203
Posts: 11 |
My 2005 Roadster is in dire need of 2 (new) catalytic converters which my garage is struggling to source (along with 4 x Lamda sensors).
Any helpful suggestions appreciated (keep it simple please!)
Jonah
2005 Roadster Rolls Royce Fireglow Red 1999 Lotus Elise S1
Posts: 21,865 Likes: 167
Posts: 21,865 Likes: 167 |
Try Autodoc: https://www.autodoc.co.uk/spares-search?keyword=AU5A-9D370-FCThe sensors on my 2005 are as follows:Upstream nearside with a grey latch plug is YL84-9F472-AE. Upstream offside with a green latch plug is IS7F-9P472-AB. Both have four wires. 2xwhite, grey and black. It is not obvious why these are different, other than the nearside needs a longer cable run. The latch plugs are the same design. Downstream of the catalysts, the sensors are the same both sides, with blue latch plugs. 2S7A9G-444BA, and again with four wires. 2xwhite, grey and black. You will probably have to source bespoke catalysts, and I'm looking now to get one for my GDi. Some exhaust specialists will offer this service.
Posts: 35,770 Likes: 468
Posts: 35,770 Likes: 468 |
Any helpful suggestions appreciated (keep it simple please!) These people have a good reputation. Powerflow
Posts: 31 Likes: 4
Posts: 31 Likes: 4 |
My 2005 Roadster is in dire need of 2 (new) catalytic converters which my garage is struggling to source (along with 4 x Lamda sensors). Sorry my daft question, but how do you recognise catalytic converters are due ? And how many miles has the car ? Thanks, Peter
Posts: 5,217 Likes: 121
Posts: 5,217 Likes: 121 |
My 2005 Roadster is in dire need of 2 (new) catalytic converters which my garage is struggling to source (along with 4 x Lamda sensors). Sorry my daft question, but how do you recognise catalytic converters are due ? And how many miles has the car ? Thanks, Peter No such thing as a daft question in my view. Especially as I don’t know the answer to the question you posed, .
Posts: 1,951 Likes: 40
Posts: 1,951 Likes: 40 |
My cat started leaking around the pipe-to-cat weld at about 45k miles. Noticed as the exhaust note became rorty and if you held the back of the hand to it, you could feel the escaping gas. My wizard local garage welded it up very successfully. I guess other indicators of a failing cat would be on the emissions test during the annual MOT test. I have also known of the innards of a cat falling loose, blocking the exhaust with a corresponding extreme power loss.
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
The catalyst should be able to be regenerated if the ceramic honeycomb it is on is in one piece and you can buy cat cleaners. My T16 P4 kept breaking the weld but they can be repaired
Posts: 531 Likes: 5
Posts: 531 Likes: 5 |
I would be interested in knowing more about this as well. At my last service one of the comments was that one of the internal baffles had become loose. The rattle at low revs is annoying but doesn’t seem to have any effect on emissions, yet, MOT passed ok. Any idea if this is terminal or if not how long the Cat has left ? Also whether it may affect performance.
Andrew 'Alice' 2013 Duratec Plus 4. Pearl Blue
Posts: 290 |
Librands used to do a "sports" cat for the roadster, might be worth a call.
Posts: 7,916 Likes: 216
Posts: 7,916 Likes: 216 |
Librands sports CAT pair are listed for Roadster 3.7 although no price given as seemingly to special order only.
