0 members (),
434
32
SORN
New
Topics48,372
Posts813,497
Members9,215
Posts: 11 |
My 2005 Roadster is in dire need of 2 (new) catalytic converters which my garage is struggling to source (along with 4 x Lamda sensors).
Any helpful suggestions appreciated (keep it simple please!)
Jonah
2005 Roadster Rolls Royce Fireglow Red 1999 Lotus Elise S1
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Try Autodoc: https://www.autodoc.co.uk/spares-search?keyword=AU5A-9D370-FCThe sensors on my 2005 are as follows:Upstream nearside with a grey latch plug is YL84-9F472-AE. Upstream offside with a green latch plug is IS7F-9P472-AB. Both have four wires. 2xwhite, grey and black. It is not obvious why these are different, other than the nearside needs a longer cable run. The latch plugs are the same design. Downstream of the catalysts, the sensors are the same both sides, with blue latch plugs. 2S7A9G-444BA, and again with four wires. 2xwhite, grey and black. You will probably have to source bespoke catalysts, and I'm looking now to get one for my GDi. Some exhaust specialists will offer this service.
Posts: 35,800 Likes: 475
Posts: 35,800 Likes: 475 |
Any helpful suggestions appreciated (keep it simple please!) These people have a good reputation. Powerflow
Posts: 31 Likes: 4
Posts: 31 Likes: 4 |
My 2005 Roadster is in dire need of 2 (new) catalytic converters which my garage is struggling to source (along with 4 x Lamda sensors). Sorry my daft question, but how do you recognise catalytic converters are due ? And how many miles has the car ? Thanks, Peter
Posts: 5,235 Likes: 127
Posts: 5,235 Likes: 127 |
My 2005 Roadster is in dire need of 2 (new) catalytic converters which my garage is struggling to source (along with 4 x Lamda sensors). Sorry my daft question, but how do you recognise catalytic converters are due ? And how many miles has the car ? Thanks, Peter No such thing as a daft question in my view. Especially as I don’t know the answer to the question you posed, .
Posts: 1,961 Likes: 43
Posts: 1,961 Likes: 43 |
My cat started leaking around the pipe-to-cat weld at about 45k miles. Noticed as the exhaust note became rorty and if you held the back of the hand to it, you could feel the escaping gas. My wizard local garage welded it up very successfully. I guess other indicators of a failing cat would be on the emissions test during the annual MOT test. I have also known of the innards of a cat falling loose, blocking the exhaust with a corresponding extreme power loss.
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
The catalyst should be able to be regenerated if the ceramic honeycomb it is on is in one piece and you can buy cat cleaners. My T16 P4 kept breaking the weld but they can be repaired
Posts: 532 Likes: 5
Posts: 532 Likes: 5 |
I would be interested in knowing more about this as well. At my last service one of the comments was that one of the internal baffles had become loose. The rattle at low revs is annoying but doesn’t seem to have any effect on emissions, yet, MOT passed ok. Any idea if this is terminal or if not how long the Cat has left ? Also whether it may affect performance.
Andrew 'Alice' 2013 Duratec Plus 4. Pearl Blue
Posts: 290 |
Librands used to do a "sports" cat for the roadster, might be worth a call.
Posts: 7,948 Likes: 218
Posts: 7,948 Likes: 218 |
Librands sports CAT pair are listed for Roadster 3.7 although no price given as seemingly to special order only.
