7 members (Craig Jezz, MOG42, Lordofthewings, Lance, IcePack, MJF, JMcL),
369
33
Topics49,918
Posts838,244
Posts: 12,269 Likes: 324
Posts: 12,269 Likes: 324 |
Excellent job DB, well done. Beautiful patina on that leather.
Posts: 8,712 Likes: 501
Posts: 8,712 Likes: 501 |
Made a pair of headlight support tubes and lugs for a pals pre-war Standard engined 4-4.
Bottom lugs are standard 1 1/4" bumper clamps but the top lug had to be fabricated from 4 separate parts then welded all together and the welds smoothed over with files and emery cloth. Then into the jig I made when making the ones for my car then brazed them all up.
Arwyn Ah, proper brazing - an almost lost skill nowadays
1 member likes this:
Arwyn Williams |
Posts: 832 Likes: 23
Posts: 832 Likes: 23 |
Drove it to Techniques in Stotfold for its annual service. Nothing major just a few electrical gremlins and one of the very last original mechanical items on the +8, lasted 45 years has finally given up the ghost. The fan in the fan heater. Only used to aid cooling when running hot. I think everything else under the bonnet and below the dash has expired at least once. All set now for Spa Classic in a couple of weeks and a drive down to Umbria in September
1980 +8 Blue And a few others ---------------- Stephen
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Agreed
That and silver soldering!
Having said that I've just retubed a 1933 Super Sports chassis. 150 quids worth of cold drawn seamless steel tubing held together by 175 quids worth of silver solder.....
Arwyn
2 members like this:
+8Rich, Graham, G4FUJ |
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
You dont laze about Arwyn , well done .
99 plus 8 indigo
Posts: 460 Likes: 80
Posts: 460 Likes: 80 |
Yesterday, actually, I removed the failed electric fuel pump. The engine started sputtering about a quarter mile from home and I nursed it into the driveway before it quit. A replacement is on the way.
Installed the new pump. I went with a Facet "Red Top" and it's much quieter than the old Holley. Switched from barbed hose connections to AN type fittings like the rest of the system. ![[Linked Image]](https://tm-img.com/images/2025/07/17/Facet.md.jpg) Strange that the Talk Morgan Image website distorted the picture, but you get the idea...
I guess someone fixed the picture...
Relative to the vast knowledge base here on Talk Morgan, I'm a newbie and wondered if silver soldering is the method the factory used to fabricate the chassis. Agreed
Arwyn
Posts: 85 Likes: 18
Posts: 85 Likes: 18 |
Un grand entretien chez Morgan Huile moteur, filtre, Huile differentiel, Purge liquide de freins, nouveaux pistons tambours, Graissage suspension Etc
