5 members (Bunny, Bitsobrits, MJF, jbk, Soleng), 310 guests, and 48 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 133 of 164 1 2 131 132 133 134 135 163 164
Excellent job DB, well done. Beautiful patina on that leather.
Originally Posted by Arwyn Williams
Made a pair of headlight support tubes and lugs for a pals pre-war Standard engined 4-4.
Bottom lugs are standard 1 1/4" bumper clamps but the top lug had to be fabricated from 4 separate parts then welded all together and the welds smoothed over with files and emery cloth.
Then into the jig I made when making the ones for my car then brazed them all up.
Arwyn
Ah, proper brazing - an almost lost skill nowadays thumbs
1 member likes this: Arwyn Williams
Drove it to Techniques in Stotfold for its annual service.
Nothing major just a few electrical gremlins and one of the very last original mechanical items on the +8, lasted 45 years has finally given up the ghost. The fan in the fan heater. Only used to aid cooling when running hot. I think everything else under the bonnet and below the dash has expired at least once.
All set now for Spa Classic in a couple of weeks and a drive down to Umbria in September
1980 +8 Blue
And a few others
Stephen
Agreed
That and silver soldering!
Having said that I've just retubed a 1933 Super Sports chassis. 150 quids worth of cold drawn seamless steel tubing held together by 175 quids worth of silver solder.....
Arwyn
2 members like this: +8Rich, Graham, G4FUJ
You dont laze about Arwyn , well done .
99 plus 8 indigo
Yesterday, actually, I removed the failed electric fuel pump. The engine started sputtering about a quarter mile from home and I nursed it into the driveway before it quit. A replacement is on the way.
Installed the new pump. I went with a Facet "Red Top" and it's much quieter than the old Holley. Switched from barbed hose connections to AN type fittings like the rest of the system.
Strange that the Talk Morgan Image website distorted the picture, but you get the idea...
I guess someone fixed the picture...
Relative to the vast knowledge base here on Talk Morgan, I'm a newbie and wondered if silver soldering is the method the factory used to fabricate the chassis.
Agreed
Arwyn
Un grand entretien chez Morgan
Huile moteur, filtre,
Huile differentiel,
Purge liquide de freins, nouveaux pistons tambours,
Graissage suspension
Etc
