Topics49,870
Posts837,673
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Very nice looking colour. I have not seen a red P4SS in the metal yet. I´m very happy with my RAF blue car as well but this red colour tone is the best red I have ever seen on a Morgan (based on viewing the pics).
I choose the same solution for the front nr-plate. Looks very cool.
Congratulations.
Posts: 32 |
Thanks for all the replies, I will be sure to take plenty more pictures and post them soon. Yes, very happy with how RPM did the front plate, a neat solution. Plan is to also fit a luggage rack ready for some summer touring round Scotland!
Plus 4 SS Caterham CSR 260 Defender 50th 993 Targa Discovery 4
Posts: 217 |
The battery on my super sport has gone completely flat and I have had to re charge by removing the battery cover from behind the seat, the 12v outlet under the dash does not allow me to trickle charge the battery, has anyone else had the same peoblem or have I an issue with my car. Alan
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
The battery on my super sport has gone completely flat and I have had to re charge by removing the battery cover from behind the seat, the 12v outlet under the dash does not allow me to trickle charge the battery, has anyone else had the same peoblem or have I an issue with my car. Alan just ask your dealer to make a easy connection behind the seat mine did and it turned out to be handy although I did drive mine often enough!!!!
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 90 |
Seeing the comment about the flat battery I went out and tried my P4 SS. It was a bit groggy at first (like the driver) but soon burst into life. The car has not been driven for about a month.
I plugged the 11 year old battery conditioner into the 12 V socket and after about 18 hours the red has turned to green. I would therefore assume the socket is okay, so you might have a problem, or the charger is faulty.
Posts: 152 |
The battery on my super sport has gone completely flat and I have had to re charge by removing the battery cover from behind the seat, the 12v outlet under the dash does not allow me to trickle charge the battery, has anyone else had the same peoblem or have I an issue with my car. Alan Hi, Did you check the fuses ? BR. Daniel.
Posts: 497 |
I'm charging mine with a Optimate battery tender connected to the power socked under the dash, it works fine.
Posts: 3 |
I'm using the CTEK MULTI SS 3600 plugged into the power socket under the dash of my new Plus 4SS. Works well. I had a flat battery before I started using the charger; I guess it was a case of putting the car away with a partly charged battery and leaving it for a week or two. What I don't understand is why Morgan's immobilisers flatten the battery when other cars' immobilisers don't. Does anyone know?
The Wanderer Returned Ex +4, +8 owner and hooligan. Now OAP, +4SS owner, still hooligan. Happy days!
Posts: 497 |
I have several modern cars that sit idle for long periods, they all run the battery flat in 3 - 4 weeks, unless I use a battery tender.
Posts: 198 |
Matthew, a great colour combo, best I have seen, well done! Tony
