5 members (Soleng, britmog, BobtheTrain, vbalddave, Socalm3w), 305 guests, and 55 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 2 of 4 1 2 3 4
Have seen a robot mower in action on a friends lawn. Impressive and worth investigation.
If won’t pour you a beer though cheers
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
👍🏻Husqvarna
Morgan Roadster S2
Jaguar F Pace S
WW2 Jeep
A friend recently purchased a Parkside robot mower from LIDL, it's brilliant!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
The Robot mowers are hedgehog destroyers if not monitored closely - friends of ours run a Hedgehog Rescue centre and see far too many macerated hogs this time of year..
2 members like this: Ruut Bianchi, Hamwich
My Honda petrol mower caught fire and, as it was elderly anyway, I considered it a write off. Initially bought a 19 inch Greenworks 40V battery mower, which has a 'sort of' mulching function; ok, but not great. I now have a 21 inch Mountfield which, despite being larger than the Greenworks, is lighter yet more powerful, has a better range of cutting heights and a rear roller for a light stripe effect, and the batteries and charger seem to be much improved.
Plus Six "Rachel"
Volvo C40
Smile, it confuses them
My first house was a flat, quite large lawn and dad was moving to a flat so I got a petrol model with geared drive from him. Benefits - easy for the cutting as it pulled itself along, other than that it weighed a ton to move around in the garage etc.
Moved to a house on a bank/hill and the petrol model was useless, no grip to get up the inclines so I went to a rotary mower, cabled electric. Way easier to use on the slopes but a faff with the power cable. Moved over to a Ryobi battery rotary and it was a mix. A little heavier with the battery but so much easier to just get out, use and then put away. Much faster as you can move about freely without fearing for the cord. I borrowed a self-driving one but it was all over the place as the lawn was not flat.
Feedback from a neighbour was that the automatic ones were good on his front lawn which was flat but he had to put a number of markers(?) to limit it's freedom which he found rather expensive. The results were good on a clear lawn but the bucket was quite small and so repeated use with short cutting was the order of the day. It did do the full garden on one cut (and a couple of emptying runs it did itself) quite easily. It was fairly quiet but he tended to still only run it when he was around to keep an eye on it as it was the front garden. He did have an issue with the local cats, most thought it was Satan but one kept sitting on it when it was working which caused the alarm to sound.
For human operated battery the trade off seems to be higher powered battery is heavier but has more grunt to do the job without retracing your steps. I tried an 18v mower and the 36v and went with the 36v which was heavier but did a lot better in one sweep. The ability to use the batteries in a selection of tools tends to mean you end up with a couple of batteries which give flexibility and enough grunt if you forget to charge one. Useful tools to mix them with were a water jet blaster because you could just fill a bucket and give something a quick blast. A leaf blower/sucker was quite good but the cabled powered one I had was significantly better for sucking wet stuff.
C'mon Chris you need some exercise laugh2
1 member likes this: Themorganeer
Originally Posted by BLUE+4
Buy a sheep......
laugh2 laugh2 thumbs
Ride on option too... innocent
rofl rofl
SWMBO asked me get a robot mower after they were saying how
good they are on her gardening blogs (instagram or whatever).
I grumbled but did as I was told, after a bit of research I went for the
Mammotion Luba mini AWD (no border wiring or markers needed
you train it by driving it round borders using your phone as a remote
or just let it use its cameras AI and sensors to map everything
I was cynical as to how something with a 8" spinning disc with little
blades on the end could compete with my 55cm 4 stroke Toro, but
it just trundles off and does the job leaving better stripes than i did.
Rich, the camera uses AI to avoid hedgehogs,pets etc when mowing.
good but a nuisance at the moment with apples falling
IanB
2010 Two tone Roadster
XK8 for sensible use.
Page 2 of 4 1 2 3 4
