1 members (Johnnyboy),
200
Topics49,918
Posts838,255
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
I have an awful rattle up front, when I gently apply the brakes it goes.
I can only assume it’s the pads rattling. They don’t appear that loose in the calliper.
Anyone help with this one?
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 25 Likes: 2
Posts: 25 Likes: 2 |
This may be worth trying, if not already used. I have , on my Plus 4, an additional “shim/ anti rattle plate” , I put a smear on all the non friction surfaces. It might help on your car. ![[Linked Image]](https://tm-img.com/images/2025/08/25/IMG_0438.md.jpeg) ![[Linked Image]](https://tm-img.com/images/2025/08/25/IMG_0439.md.jpeg)
Posts: 8,712 Likes: 502
Posts: 8,712 Likes: 502 |
I sometimes get an annoying rattle from the passenger area if I don't apply the brakes  Sorry, on a more sensible issue above, pop out and clean up all the pads and as Bishmog recommends, use some CeraTec as it's safe with ABS equipped cars
1 member likes this:
Alistair |
Thanks Chaps.
I’ve taken them out and cleaned them.
I wonder if that Cera tec would work like Copperslip?
Coppaslip is very old tech and if you have ABS sometimes has issues because it's conductive, I swopped to CeraTec several years ago
Posts: 37,493 Likes: 994
Posts: 37,493 Likes: 994 |
Thanks for that tip Jon, still using Coppaslip.
It’s ok. Having just taken a wheel off again it suddenly dawned on me that it’s the floating discs rattling
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Me too still using Coppaslip and Aluslip, the tubes seem to last for ever!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
It’s ok. Having just taken a wheel off again it suddenly dawned on me that it’s the floating discs rattling I have no idea of the system used by Morgan, but googling floating discs, it says that whilst they are noisy on race cars, road going vehicles usually have some form of damping such as springs. If they rattle it could be due to worn rivets or springs. The question to be considered is whether they have always been like that or is it a more recent occurence?
Yes indeed. I bought them off Simon Bloje, can’t remember the company but I should’ve bought them from my original supplier.
Not done many miles so pretty sure they’ve not worn out the springs. I’m reckoning they’re race spec hence the noise.
