2 members (Julian BB, Marmota), 336 guests, and 45 robots.
+8Rich 93
Posts837,277
well doesn't worry me... the noise that is... can't hear much above the noise of the car!
Black Rat
Black Rat
My car 2013 +4 doesn't have the spring thing (could it be because of the AC) but it has a spade connector nearby not connected to anything it has 2 red /red orange wires. Fan only runs fast and noisy.
Keith
2013 narrow bodied + 4 Ruby.
According to schematic for your car Keith there should be a red/green cable from slow speed relay that routes through the Ford resistor and on to fan motor. The red/orange cable you mention is common feed to fan motor connector after junction of the two relays output (slow via resistor). Another clue to its existence will be a bank of six identical relays - starter, fuel pump, ECU, fan low, fan high, air con. The car is wired for air con if fitted or not.
Black Rat
Black Rat
I'll take another look Richard.
Keith
