Topics49,839
Posts837,302
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
well doesn't worry me... the noise that is... can't hear much above the noise of the car!
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
My car 2013 +4 doesn't have the spring thing (could it be because of the AC) but it has a spade connector nearby not connected to anything it has 2 red /red orange wires. Fan only runs fast and noisy.
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
According to schematic for your car Keith there should be a red/green cable from slow speed relay that routes through the Ford resistor and on to fan motor. The red/orange cable you mention is common feed to fan motor connector after junction of the two relays output (slow via resistor). Another clue to its existence will be a bank of six identical relays - starter, fuel pump, ECU, fan low, fan high, air con. The car is wired for air con if fitted or not.
I'll take another look Richard.
