10 members (Burgundymog, Paulxj, DickJ, Sir Percival, TheRabbit, verysideways, Ian Wegg, Clipper, GrumpyPa, gaston), 308 guests, and 55 robots.
+8Rich 92
Topics49,837
Posts837,286
well doesn't worry me... the noise that is... can't hear much above the noise of the car!
Black Rat
Online Sad
Black Rat
My car 2013 +4 doesn't have the spring thing (could it be because of the AC) but it has a spade connector nearby not connected to anything it has 2 red /red orange wires. Fan only runs fast and noisy.
Keith
2013 narrow bodied + 4 Ruby.
According to schematic for your car Keith there should be a red/green cable from slow speed relay that routes through the Ford resistor and on to fan motor. The red/orange cable you mention is common feed to fan motor connector after junction of the two relays output (slow via resistor). Another clue to its existence will be a bank of six identical relays - starter, fuel pump, ECU, fan low, fan high, air con. The car is wired for air con if fitted or not.
Black Rat
Online Sad
Black Rat
I'll take another look Richard.
Keith
