1 members (+8Rich),
311
Topics49,915
Posts838,214
Posts: 2 |
Last week I became the happy owner of 1985 4/4. I can't remove key when ignition is turned off.????
Posts: 28,914 Likes: 354
Posts: 28,914 Likes: 354 |
Congrats on the new car and welcome to TM!  Suggest posting your question in the Classic (pre-CX) section OR the Maintenance and Servicing section - you may get more replies in one of those
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
Welcome to TM Gary, noting Graham's comment above. The key mechanism can get gummed up, try WD40 whilst wiggling key. Probably worth having a spare anyway whilst they're still available. ![[Linked Image]](https://i.ebayimg.com/images/g/dNQAAOxyzGlQ7u6m/s-l1600.jpg)
Posts: 5,608 Likes: 617
Posts: 5,608 Likes: 617 |
On my earlier car you need to push the key inwards and turn it 'off' further to pull it out ... may be the same for you
Posts: 6,680 Likes: 441
Posts: 6,680 Likes: 441 |
Couple of things - as reflected in another thread here - I've heard that a large/heavy bunch of keys can cause issues as it put undue strain on the internal mechanism.
If you have to replace the ignition barrel, have a look at MGB ones - I replaced mine a few years back and the MGB one was virtually identical and a fraction of the Morgan price.
Getting the old one off can be a little tricky, but I drilled and snapped mine out - if you get to that stage let me know and I'll let you know what I did.
Posts: 12,268 Likes: 324
Posts: 12,268 Likes: 324 |
Getting the old one off can be a little tricky, but I drilled and snapped mine out - if you get to that stage let me know and I'll let you know what I did. This, definitely. I replaced mine years ago with an MGB lock. I cut the old one off with an angle grinder. The other thing to do if you're able to keep your car in a garage or somewhere safe is to not break off the bolt heads when you install the new lock. They come with intentionally weak bolts, the idea is that the heads break off when you tighten them up, thus making it hard for a Ne'er-do-well to remove them should they want to nick your car. I left mine as is to make it easy to remove the ignition lock should I need to. But having said that it must be at least 15 years since I put the new lock on and I've not needed to remove it again.
Last week I became the happy owner of 1985 4/4. I can't remove key when ignition is turned off.???? Have you tried wiggling the steering wheel to ensure the steering lock has disengaged properly?
The other thing to do if you're able to keep your car in a garage or somewhere safe is to not break off the bolt heads when you install the new lock. They come with intentionally weak bolts, the idea is that the heads break off when you tighten them up, thus making it hard for a Ne'er-do-well to remove them should they want to nick your car. I left mine as is to make it easy to remove the ignition lock should I need to. But having said that it must be at least 15 years since I put the new lock on and I've not needed to remove it again. Yep, I just swapped mine for a couple of Allen bolts and countersunk them into the body so they're not visble. The fact that all the wiring is hanging out the otherside and steering locks can be snapped with a sharp tug meant that I didn't think security bolts were that important in this situation!
2 members like this:
Hamwich, Graham, G4FUJ |
I did the same as Tim when I replaced the switch on my '76.
Posts: 308 Likes: 31
Posts: 308 Likes: 31 |
On my 1977 plus 8 you need to turn the key to the off position, then press a little tab on the steering lock above the key in, and then turn the key a little further and then you can extract it. The tab is above the key. It's a bit of a fiddle with no apparent advantage that I can see.... On the other hand, on the 69 4/4, the key will just fall out. And on my first car, 50 years ago, an Mg Midget, a screwdriver was a perfectly good substitute for the key, as the thief who took it out of the local pub car park demonstrated. They did not get far, as the throttle cable broke 3 miles down the road. I miss that car ....
Dave Blue 4/4 1969, Green +4 1953, (different) Green +8 1977
