10 members (Graham, G4FUJ, John V6, RJW, AZJowett, RedThree, Alistair, JMcL, Orjan, Scrambledsignals, Luddite),
97
44
Old Book
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
Topics49,937
Posts838,576
Posts: 22,386 Likes: 359
Posts: 22,386 Likes: 359 |
Posts: 317 |
thank you Dave. Good to know
2005 Roadster 3.0 S1 1960 MGA Roadster
Regards Aage
I've just ordered a set of plugs. I like to keep a service stock!!
Posts: 8,726 Likes: 514
Posts: 8,726 Likes: 514 |
I fitted NGK Iridium ITR6F13 to my S1 at 40k miles and was amazed at how good the previous set looked when removed, clean as a whistle, and minimal gap increase of perhaps just a couple of thou
I've always been a fan of NGK plugs, never had quality issues
Posts: 166 Likes: 15
Posts: 166 Likes: 15 |
I'm sure lots of you remember when for ages you could get 4 Champions for £1! At 5s. 0d. a spark plug cost about the same as a gallon of petrol!
1999 4/4 Lowline
Posts: 502 |
Bit of advice needed please. I'm planning on checking my spark plugs and been reading Dave Ws method. However, reading the roadster handbook it states that the intake manifold should notnbe removed by the owner as the fuel settings need to be checked. Is this even a thing?
2004 Series 1 Roadster
Bit of advice needed please. I'm planning on checking my spark plugs and been reading Dave Ws method. However, reading the roadster handbook it states that the intake manifold should notnbe removed by the owner as the fuel settings need to be checked. Is this even a thing? I asked the very same thing at my dealer before doing that job. Providing you take care with the gasket, you dont interfere with the fuel lines, so it's a simple mechanical separation and reassembly. So I did it and there were no issues.
Posts: 502 |
Thanks Dave. I'm planning on replacing the PCV at the same time, do you think there's sufficient clearance to get at it if I prop up the manifold like you did in your photo on here? I don't have hands like shovels so that might help.
Possibly Leroy. Access is very tight when you leave everything connected, but see how you go.
Posts: 502 |
Thanks Dave. I'll post an update how I get on, as it might help out someone else.
