Morgan Aero 8
0 members (), 297 guests, and 67 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
Hello everyone,
My apologies if this isn't the correct place to post this, it is my first post on the forum.
I'm having a little bit of trouble and can't quite figure out what to do about it. I have a 2001 Plus 8 that is completely stock, but I keep having an issue with it not starting. I replaced the battery, same problem. Replaced it again same problem. I can get it to start with a jump box and once it's going it seems to run fine - minus not being able to run the signals. With that being said, I hooked up a larger more traditional 12v battery I had and it fired right up - now we enter the main problem - Traditional battery won't fit under the hood and I don't want to move the fuel filter.
Does anyone have any tips or tricks they would recommend? Anyone ever experienced this?
The battery on it right now is a gel Odyssey Extreme 12V ODS-28AGML with 330 CCA. Just doesn't seem to have the amperage I need for the car to operate.
Thanks in advance for any help!
Mulberry fabrications have a kit to relocate the battery to the rear of the car, if you do that then there is plenty of room for a good sized lead acid battery,
However, The Odyssey should have sufficient grunt to start the car, so I would check out the starter motor and electrics.
Brian
Jersey and Spain
You've obviously found the correct place to post the query, so I will head there in case I can add anything smile
The Plus 8 mentioned here is the Aero8 based plus 8, not the Rover version.
Oops. Note to self, must check the Forum before posting
Brian
Jersey and Spain
Smile, it confuses them
So easy to confuse things, they all look the same right (except the cross eyed ones)
