0 members (), 330 guests, and 52 robots.
+8Rich 94
Posts837,276
My 4/4 is used 12 months of the year. Having just changed the front brake disk pads and put in a new air filter I am looking forward to taking it on a run through the incredible autumn colours to be seen here in Devon. Hopefully I shall soon be able to share some images with you all, of the beech woods on Haldon at the top of Blackbird Hill.
Graham
Octogenarian - (82)
1.8 4/4 Ivory
ToyoYarris
VolvoV70
The only time I've had fuel go off in a big way was an MGB under an 18 month refresh. I'd only left a couple of gallons in, deliberately, because I figured that was better than having a full tank go off.
Those two gallons went off spectacularly. It didn't even smell like petrol and because it had evaporated in the lines, left a sticky green deposit on everything so it took some shifting. Then I had to drain the tank. Because the B tank has the sender on the side, it's possible to remove the sender and shine a torch to inspect the interior. What that showed was a patch of rust, directly under the fuel pipe, because below the take off pipe is a low point. Also, because the front edge of the tank is also a low point, there was a line of rust. The rust is either water in the petrol, or condensation.
With an injection engine it would be a lot more difficult to sort out bad fuel.
formerly known as Hugh Jorgan
Drive it, fill it up with petrol....drive it, fill it up with petrol......!!!!😁
There are always some great days for getting out in the winter..... and no chance of getting sunstroke.......🥵
Time to get all those huge and dusty flying jackets out of the wardrobe and make use of them....👍🏼
2 members like this: +8Rich, John V6
Black Rat
Black Rat
Drive it all year around unless they have salted the roads then I wait for a good downpour to wash the roads.
Keith
2013 narrow bodied + 4 Ruby.
1 member likes this: +8Rich
