Topics49,838
Posts837,294
Posts: 121 Likes: 1
Posts: 121 Likes: 1 |
Would anyone know the size of the nut that is holding the drive pulley on the bevel box? Socket size for removal
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
The nut is 54mm across the flats.
2 members like this:
Hogzilla, Pyewacket |
Posts: 23 Likes: 2
Posts: 23 Likes: 2 |
I’ve just replaced the oil seal on mine and that nut was very, very, very tight as was the drive sprocket which required a hefty puller.
1 member likes this:
Hogzilla |
Posts: 79 Likes: 23
Posts: 79 Likes: 23 |
Because working now nearly 2 year on the Bevel-box, maybe this is the answer.
We have found that they all were M40 1.5 with a collar, key 55mm As far as we know only Quaife has the exactly right ones, with the collar inside the nut.
We use in our project M40 x 1.5 with a colour which extends. The ones we use and have for sale are Key 50mm Most M3W do not have a dustcover on the swing-arm at that side. It is better to make an inside dustcover to protect the left bearing of the swing arm.
BTW Our Bevel box project has done now several bench and drive test and the results have even flabbergasted us. No noise, no vibration. For the first time I hear a little 'swoesj' of my chain-drive ;-0
One ant does not know anything, 2000 are a super-intelligent brain. That's like this helpful forum.
Posts: 79 Likes: 23
Shitty AI correction colour is of course 'collar'
