1 members (MK3), 246 guests, and 79 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 26 of 79 1 2 24 25 26 27 28 78 79
le Asbo du Bling
le Asbo du Bling
Never had an issue when I used it on the tubed wire wheels of my old Jag.
Slowly going green
they are tubed tires.
AQM Offline
I was told early on that they weren't tubed tyres. Did they change them to tubed?
If they are still the Avon 4.00x19 65S, Avon has those listed as a tubed tire.
What would the disadvantage/advantage be of a tube tire compared to a tubeless tire on the M3W?
AQM Offline
The rear IS a tubeless, so a real advantage there would be to be able to make do with a tyre plugging kit, no extra tubes and so forth.
Another advantage of tubeless tires is that there is no tube to be pinched if you're running with low pressure in them (sand).
And yes, you can get spoked wheels that are tubeless smile
Aeroman Offline OP
Originally Posted By 1560
I got the toolkit (with tire-repair like in an aero)
suppose they think we always hang out togehter A'man wink
laugh2 laugh2
Brian
2014 Morgan SP1 (Rocket Red)
Aeroman Offline OP
Good luck on your 3W pick-up tomorrow Asbo, don't forget to post loads and loads of camera flag
grin2
Brian
agreed...and video (if possible)
le Asbo du Bling
le Asbo du Bling
grin2
Sounds ominous, just bought a go pro but probably pushing my luck trying it out tomorrow. Only one sleep to go woohoo
Slowly going green
Stick some tape on the mount where the camera slides into it...otherwise you will pick up a rattle! A tip from the Go pro website......they obviously have had a few complaints! A brilliant bit of kit though.
