Topics49,846
Posts837,376
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
Never had an issue when I used it on the tubed wire wheels of my old Jag.
Slowly going green
Posts: 836 |
Posts: 870 |
I was told early on that they weren't tubed tyres. Did they change them to tubed?
Posts: 836 |
If they are still the Avon 4.00x19 65S, Avon has those listed as a tubed tire.
What would the disadvantage/advantage be of a tube tire compared to a tubeless tire on the M3W?
Posts: 870 |
The rear IS a tubeless, so a real advantage there would be to be able to make do with a tyre plugging kit, no extra tubes and so forth. Another advantage of tubeless tires is that there is no tube to be pinched if you're running with low pressure in them (sand). And yes, you can get spoked wheels that are tubeless
Posts: 7,363 |
I got the toolkit (with tire-repair like in an aero) suppose they think we always hang out togehter A'man
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 7,363 |
Brian
Posts: 836 |
agreed...and video (if possible)
Good luck on your 3W pick-up tomorrow Asbo, Sounds ominous, just bought a go pro but probably pushing my luck trying it out tomorrow. Only one sleep to go
Slowly going green
Posts: 14,009 |
Stick some tape on the mount where the camera slides into it...otherwise you will pick up a rattle! A tip from the Go pro website......they obviously have had a few complaints! A brilliant bit of kit though.
