4 members (Alastair, Stevecarr, Clipper, JMcL), 355 guests, and 48 robots.
+8Rich 94
Posts837,276
Page 5 of 5 1 2 3 4 5
MUE Offline OP
The injectors weren't tested. It wasn't even running anymore. Now I can just take it to a garage for a quick trip.
The ignition cables were replaced. They are approximately 4 years old.
I don't fill up with E10 in this car.Only E 5.
Even E5 degrades over time I use Stabil if the CX isn't used much like over winter.
MUE Offline OP
So, I just installed the new filter and let it run for 15 minutes. It's running smoothly again, no longer sputtering, and is running normally. I think it really was mainly the ECU,
and all the trying to get it started when it wouldn't, there was probably still a lot of fuel in the system, which caused the sputtering.
I want to thank you all again for the great help! Fantastic!
I have one more small question. It was idling and even got over 100 degrees Celsius. But the fan never came on, and I'm a big fan of it kicking in early.
There's the electrical connection on the fan and the temperature sensor somewhere. Where is that located? Or is it normal for it to come on very late?
I didn't want to overheat it any further.
jbk Offline
Sven there is likely to be an Otter switch at the base of the radiator best check the information on GoMog, regards John k
ps the temperature gauges are renown to be inaccurate.
1993 T16 +4 Lancia Blue.
1 member likes this: MUE
