What I hope to do with the Blue tooth MP3 player (very similar to an IPOD shuffle), is load up all my songs and pair it to the Music Stream (and may even hard wire it in so it recharges, but there are USB ports I can use,just need to find a way to tidy up the wiring so its not obvious) and leave it in the car. The MP3 player in mind has a simple single button to connect to any blue tooth device eg Music Stream and hopefully it will recognise it everytime I switch the engine on, then hit another button to just play my recorded songs. If I need sat nav or radio etc I'll just pair up the phone.
Well that's the theory. I'll let you know if it works. I'll also when the weather improves will look at the front speakers and see if I can perforate the double lining behind the leather to allow more music to pass through.
It certainly appears that the Plus Four handling pack would be on my list of preferences especially if using the car in wet and slippy conditions eg regularly over winter. Yet to see how it performs on dryer roads.
