10 members (+8Rich, Ady42, Luddite, JMcL, Joske Vermeule, Arwyn Williams, John V6, CooperMan, Pittsartist, Ricosan),
366
113
Topics49,869
Posts837,660
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
Interesting info Richard  I remember pratting about for days trying to get my Cruise to recognise the speed signal from the CANBUS to calibrate the set-up and gave up, eventually adding a GPS module Yes John V6 had the same issue with his cruise control fitter. Speed comes up easily enough via my OBD2 port though.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Yes I did. The fitter couldn't find how the speedo got the speed signal
Its on CANBUS so guess your fitter didn't have appropriate decode module or didn't know where to look. ![[Linked Image]](https://i.ibb.co/zhq0WTch/Screenshot-20260828-104838-Adobe-Acrobat.jpg) Haven't had need to try it but guess you could tap into the above mentioned yellow/pink wire that feeds the EPAS connector.
I gave him that schematic but it didn't work . I don't know why.
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
I gave him that schematic but it didn't work . I don't know why. Ditto, I specially wired up a break out plug (if that's the correct name ?) so as not to damage the loom and still no luck
Thankfully I've never had cause to look further but clearly the speed data is present
