6 members (AlyMatt, TrickieDickie, IcePack, David_E, PaulJ, DaveW), 280 guests, and 93 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
Well the one I took a photo of is most certainly a Mazda MX-5 gearbox as fitted to the MX-5 sports car!
The box fitted in the Three Wheeler is the same as can be seen by this photo
AQM Offline
Thanks smile
Originally Posted By AQM
Are we sure it's an "MX5 gearbox" and not an "MX 5-speed"?
I'm just curious, because on the threewheeler they write "MX 5-speed"?
Am I missing something?
Probably the 6th gear !!!!! innocent
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
E
E
The MX5 has two gearboxes. One a 5 speed on the 1.8 car and the 2.0 ltr base model and the other a six speed on the 2.0ltr sport tech and the paddle shift automatic.
eddie
AlexH Offline OP
So they use a new gearbox since the beginning of the year in the 4/4.
Do the gear ratios stay the same as last year's when I did the testdrive?
Especially 5th gear: Is it still "just an overdrive"?
The 5th gear ratio is different. The ratio was 0.76:1 on the old box and as far as I can see from the attached figures...which relate to the Australian market MX-5 but probably the same as the European spec, they are different. Interesting that they also use a 4.1:1 final drive ratio on some models.
The top gear speeds per revs is interesting too.
AlexH Offline OP
Wow, that's some thorough information!
Thanks! notworthy
