4 members (gaston, Zach, piquet, Chris Cosher), 342 guests, and 46 robots.
+8Rich 92
Topics49,838
Posts837,294
Welcome
Thanks stefan was that all the way from cats to back.
If you want to amplify the exhaust note for very little, you can buy some decat pipes, which you put back on for the MOT, you can also knock out the exhaust baffles in the main silencer with a hammer and steel rod . It won’t sound as good as a complete aftermarket system but better than a standard system. You could also remove the rear resonators and replace with a bit of polished stainless pipe. - effectively leaving you a straight through system as the main silencers area straight perforated tube .’
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
1 member likes this: Charlie8
