1 members (JoeSpeetjens),
176
Posts837,276
Posts: 31 Likes: 11
Posts: 31 Likes: 11 |
No drilling. They just have suction cups that have a lever to attach them to the surface. I gave the metal an alcohol wipe first to make sure it was clean.
Posts: 1,163 Likes: 354
Posts: 1,163 Likes: 354 |
Here is my solution. I am a big fan of SP Connect. Use the system on my motorcycles. The system needs a special shell for the phone. The suction cup can be mounted on the dashboard below the dashboard or on the windshield and is mounted or removed in 10 seconds with a turn of 90 degrees. ![[Linked Image]](https://tm-img.com/images/2023/04/23/F548FE73-6BA0-472D-BE8D-1B69DD51F174.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/04/23/4E89ACB2-4127-40B9-84C8-CFFF71FAF746.jpeg) ![[Linked Image]](https://tm-img.com/images/2023/04/23/C75A7B8A-D287-4ED3-8806-B52FA4D889CB.jpeg)
Clemens
PlusFour Red Baron MY 2022
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Might as well toss this in. Not for a CX but might fit the same and would equally work with a telephone. It uses a printed clip that fits snugly around the top dash profile with a little turned brass adapter that fits a 17mm ball thingy I found on ebay. It ‘springs’ on and off and can be slid along the dash to any position. ![[Linked Image]](https://dl.dropboxusercontent.com/s/p61y1coae1t1x4x/sat%20clip.jpg) ![[Linked Image]](https://dl.dropboxusercontent.com/s/kppf3y8mz1h1694/sat1.jpg)
Roger 2011 Plus 4
1 member likes this:
42w203 |
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
That looks superb Roger, I can't find anything like it on ebay, have you any more details at all? Nick
Also a super solution Roger. Where to get this plastic clip with dash Profile on eBay?
Clemens
Sorry chaps it’s not on ebay its a homebrew. I printed the clip after modelling it around my dash profile. But if anybody is able to print and would like a copy of the STL file they are welcome. ![[Linked Image]](https://dl.dropboxusercontent.com/s/wej2iojitk768zb/clip1.jpg)
Roger 2011 Plus 4
Thank you for the file Roger 👍😎
Clemens
Posts: 11,520 Likes: 312
Posts: 11,520 Likes: 312 |
Why not make a few Roger? You know you want to. Nick
But I only need the one….
Roger 2011 Plus 4
