7 members (uvk33n, JMcL, Luddite, Franko, IcePack, jbk, Mogdavid), 328 guests, and 33 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,916
Posts838,221
MossyfromNZ
#838128 07/02/26 03:58 PM
Apologies for a question which must have arisen many times before but I need to clean up a few scuff marks on the running boards of my 22 Plus Four. I'd prefer to blame the previous owner but in truth I know I'm the prime culprit but when I've looked at scuff repair solutions on line a number of them recommend caution which has so far deterred me from trying. My first feeble attempt with a j cloth and a drop of acetone left more scratch marks than I'd started with so any suggestions would be greatly appreciated.
TeddyAds #838131 07/02/26 04:22 PM
If the scuffs are on the protective film, it can be testing. The surface is soft and so it is easy to make it worse. Start with something like glass shine, which should be alcohol based. Don't go mad. Don't generate heat. Use a microfibre. Then move on to a Polish, not a wax. Polish has low level abrasives. After that, possibly white spirit, and then progressively more abrasive, such as plastic polish, but always slow and easy. Sometimes the surface damage is beyond saving and will need a new application.
TeddyAds #838134 07/02/26 05:06 PM
I thought they self repaired with a little from say a hairdryer
John V6 #838141 07/02/26 06:38 PM
The TM in Talk Morgan
That depends on the type of/ manufacturer of the film. Self healing is only a feature of high quality films and if this is factory installed, I would question which film they use. Previously they outsourced PPF and I know that film was not self repairing. Next time I speak with the MMC, I’ll ask what the current situation is.
Also, it doesn’t require a hairdryer - a reasonable ambient temperature will do (saying that, with the current weather… that may be some wait!)
TeddyAds #838144 07/02/26 07:01 PM
WOW ! acetone ! steady on fella, nasty stuff that, eats some paints and plastics
TeddyAds #838152 07/02/26 08:13 PM
The above implies that PPF has been fitted, I don't think that's a given. The OP doesn't seem to mention it ...
If it isn't PPF the scuff marks would likely polish out, unless they are through to the undercoat.
And if it is PPF, doesn't hot water work well?
Plus Six "Rachel"
Volvo C40
TeddyAds #838156 07/02/26 09:55 PM
Very true I was going from Dave Ws comments and referring to ppf .
I'm sure hot water also works on ppf
If no ppf you can get a colored wax polish containing t cut. It helps but isn't permanent.
Acetone on paint is not good. It removes nail varnish which is paint
TeddyAds #838157 07/02/26 10:04 PM
PPF...... I seem to recall the firm who did mine told me to use isopropyl for scuffs, sparingly. As Dave W said, don't go mad.
Hair dryer was for helping remove the film, starting by slightly lifting a corner a teeny, ween amount and playing heat beneath.
I'll try to find details, a firm in Melton Mowbray did mine but it was almost 20 years ago.
And yes, I did buy a pie!
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
TeddyAds #838160 08/02/26 01:54 AM
I did my own . Not easy on curves but has protected the running boards well. Yes heat helps also removal.
AI suggests
How PPF Treats Scuffs
Self-Healing Technology: Modern high-quality PPF contains an elastomeric polymer topcoat that reacts to heat. When exposed to heat (sunlight or warm water), the film's molecules rearrange to erase minor scratches and swirls.
Heat Gun Repair: For faster, more deliberate, or stubborn scuff removal, a heat gun or hair dryer can be applied to the scratched area to activate this healing process instantly.
Prevention & Hiding: PPF hides existing, light, surface-level scratches on the paint by filling them in with its adhesive.
YouTube
YouTube
+4
Key Considerations and Limitations
Not a Cure-All: PPF cannot fix deep gouges that penetrate through the film to the paint, or scratches that catch your fingernail.
Professional Application: For the best, most durable, and invisible result, professional installation is recommended.
Maintenance: PPF should be washed with pH-neutral shampoo and maintained with dedicated sealants to keep it from yellowing or losing its hydrophobic properties.
Applying Over Damaged Paint: While possible, it is not recommended to apply PPF over already damaged paint, as the imperfections may be trapped under the film.
RAC
RAC
+5
Types of Scuffs Affected
Best For: Minor surface abrasions, swirl marks from car washes, light scuffs from tree branches or bushes, and rock chips.
Not Effective For: Deep scratches, structural damage, or severe paint gouges that require bodywork.
M&G Automotive Detailing
+2
What Makes PPF Self-Healing? Understanding How It Works for ...
Oct 2, 2025 — What Makes PPF Self-Healing? Understanding How It Works for Vehicle Protection. ... When it comes to protecting your vehicle, most drivers think about tradition...
Easy Ways to Remove Scratches From Paint Protection Film
Dec 4, 2025 — Easy Ways to Remove Scratches From Paint Protection Film * Using the soft towel and PH neutral soap to clean the PPF film in order to reomove dirt on the scratc...
carlike wrap
Does Paint Protection Film Help with Scratches? - All Pro Wraps
May 29, 2025 — Does Paint Protection Film Help with Scratches? Understanding the Benefits in Raleigh, NC * You know that sinking feeling—when you come back to your car after s...
All Pro Wraps
Does PPF hide swirls? - Harker Heights Ceramic Coatings
Jun 15, 2022 — PPF hiding swirls and scratches? You bet. * Will PPF hide swirls? The short answer here is, it depends on the scratch. The answer is probably not if we are talk...
4:52
PPF Can HIDE scratches? BS or Fact?
YouTube·Humble Crew Auto Spa
The pros and cons of Paint Protection Film (PPF) for your car - RAC
Oct 31, 2024 — This car maintenance guide highlights why you should consider applying PPF to your vehicle. * What is Paint Protection Film (PPF)? Paint Protection Film (PPF) i...
RAC
How to Fix Scratches in Plastic Car Film: Step-by-Step Guide - terminax
Jul 3, 2025 — How to Fix Scratches in Plastic Car Film: Restore Your Wrap or PPF Like New * Plastic car films like TPU wraps and paint protection film (PPF) have become popul...
terminax
The Truth about Paint Protection Film (PPF) - Ceramic Pro
Jul 6, 2023 — During the Vietnam War, the United States Department of Defense was having trouble with rotor blades on several of their helicopters being damaged by shrapnel, ...
Ceramic Pro
Magic of Paint Protection Film for Removing Scuffs and Scratches
Feb 10, 2025 — Know the Effectiveness of Paint Protection Film for Removing Scuffs and Scratches * What is a scuff mark? * What are scratches? * How this Paint Protection Film...
UltrashieldX Paint Protection Film
Is It Possible to Apply PPF Over Areas with Existing Paint Damage?
Jan 27, 2025 — Is It Possible to Apply PPF Over Areas with Existing Paint Damage? ... When it comes to protecting your vehicle's finish, many people are curious about Paint Pr...
Detail Solutions
AI responses may include mistakes. Learn more
TeddyAds #838173 08/02/26 09:50 AM
From the original post assume there is PPF on the area. Carry on as above but try to avoid solvents!
If not then polishing the bare paint using a polish such as Autoglym might work. Depends on the depth of the scuffs/scratches. Hand polishing with a suitable applicator should work for light scuffs. Take your time and repeat as necessary. When done remember to re-wax ( or any other protective coat) to finish. There are more aggressive polishes/scratch removers to be had. Start with gentle versions for safety! Practice on something else if possible.
