2 members (PaulV, Robbie), 274 guests, and 39 robots.
+8Rich 92
Topics49,837
Posts837,286
Page 1 of 4 1 2 3 4
#838407 12/02/26 08:17 AM
Grumpy2 Offline OP
My 2012 plus 4 stops very well on the road
When the MOT man puts it on his tester however the front brakes are always quite imbalanced, there’s about 30% difference between left and right. Yet on the road it pulls up straight and true.
My yearly maintenance involves removing both calipers from the hubs and gently easing each piston in and out and applying a tiny amount of rubber lube to the seals, cleaning off all residue. There’s no sticky pistons, no deformed discs and no contaminated pads. There’s no air in the calipers and all flexible pipes look like new.
I’m soon to start my annual maintenance process and wondered if anyone might have other suggestions I could add to my jobs list?
Thanks
Gary
Oh, can someone direct me to the correct brake pads for the Caparo calipers please? I went through this route this time last year, apparently the mintex compounds aren’t approved for road use! So I swapped the pads side to side with no difference to the mot results!
Grumpy2 #838413 12/02/26 09:42 AM
Sounds as though you are doing everything right. Try a different MOT tester.
Grumpy2 #838418 12/02/26 10:02 AM
If you look at the brake line layout for post June 1993 cars … with the Caparo brakes you’ll see the introduction of diagonally paired circuits.
Your problem is likely a leaking rear slave cylinder on the opposite side rear.
https://www.talkmorgan.com/ubbthreads.php/topics/787402/re-adapter-brake-fluid
Grumpy2 #838419 12/02/26 10:05 AM
Black Rat
Black Rat
Cain fitted the race pads to my car, never had a problem.
Keith
2013 narrow bodied + 4 Ruby.
cerealsurfer #838424 12/02/26 11:41 AM
Grumpy2 Offline OP
Interesting idea but the rear brakes balance almost perfectly and there’s no sign of any leaking inside the rear cylinders (part of my annual service routine).
But I’ll check again this year to be certain.
Grumpy2 #838428 12/02/26 12:27 PM
Thanks
Gary
Given your comments the only thought I have is the calibration of his tester or the grip of each of your tyres on the rollers. As suggested try another test station.
Grumpy2 #838431 12/02/26 12:58 PM
Probably not the problem, but one of my original caparo callipers, despite being rebuilt was causing an imbalance. New callipers has solved the problem.
Think something in the manufacturer of the calliper.
RichardV6 #838434 12/02/26 01:36 PM
Grumpy2 Offline OP
I did wonder but yesterday I took the Z4 to him for testing and the results were balanced front and rear.
I’m wondering if these a possible link to the light weight of the Morgan?
Grumpy2 #838435 12/02/26 01:45 PM
I always fit these to the Morgan , be it sprinting or road use....
https://www.ebcbrakeshop.co.uk/products/ebc-greenstuff-2000-series-sport-brake-pad-set-dp2243
5% discount on 1st order
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
Grumpy2 #838437 12/02/26 01:47 PM
My experience is that the pads matter. Pads which need temperature won't heat up as much on a light car. It also matters how much of a braker you are. Mintex pads came with the ventilated disc kit for my Roadster, and gave me exactly this problem. On the rollers, balance was all over the place. On the road, it was evident for the first few seconds of application, then enough heat came in for them to work, but for my light use of brakes it didn't work. I went to Greenstuff, which were fitted whan I bought my Roadster on standard pads and no further issues. I realise that some hate Greenstuff. I also know that most find Mintex fine. For me Mintex did not work.
2 members like this: Graham, G4FUJ, Grumpy2
Page 1 of 4 1 2 3 4
