I see your rear dampers are mounted so they pivot with the movement of the axle, a vast improvements over how Morgan did it on their modern traditional chassis cars
No problem... it was only after watching it back a few times I clocked I didn't talk about the somewhat obvious fact that it still uses leaf springs and how many leaves they have.
I'm still getting used to doing all this editing... learning with every go still tbh.
You’ll see the prototype wheel in one of the next episodes…. I adjusted the Minilite measurement accordingly for the new front wheel. Then worked from that prototype for the rear.
I built up a backlog of episodes … so these were filmed in around Sept time last year.
Another Bitesize ahead of Episode 4 is released.... p.s. I've tried to turn down the music volume slightly from Episode 4 onwards... this is the last of the louder ones I'd already produced. Sorry about that... I'm learning.
