0 members (),
326
92
Topics49,847
Posts837,389
Posts: 307 Likes: 31
Posts: 307 Likes: 31 |
On my 1953 plus 4, I currently have Avon HM Tourist crossply tyres marked as follows: 145/95- 16 replaces 5.00/5.25-16. 76P 4 PLY RATING TUBE TYPE which is slightly confusing me. ![[Linked Image]](https://www.tm-img.com/images/2026/04/07/IMG_0121.jpeg) According to the Blockley web site: The Morgan Plus 4 tyre size between 1950 and 1962 was 5.25x16. From 1962 onward the factory fitted 5.60x15 using a 4" wide wheel rim (as they had fitted to the Plus4 Super Sports) which is radial equivalent 155R15 tyre size. Shortly after, the tyre size was increased by the factory to 5.90x15 with a wider 4 1/2 inch wheel rim, which is equivalent 165R15 radial size, a size that was quoted in period as the radial Plus4 option. Blockley produces both the 155HR15 and 165VR15 tyre sizes which are a period correct, steel belt construction with high speed rating and perfect for all the Morgan Plus 4’s. I have 16 x 5 inch steel wheels, (my car is pre-1962). I want to replace the tyres (now 8 years old) with a radial type. I don’t want to have to find a set of 15 inch wheels, so I’m stuck with the relatively small range of 16 inch tyres available. e.g. Blockley 185VR16 £235 Vredestein Sprint Classic 185R16 £234 The Blockleys are 27.4 inch dia which is about right for the speedo. Bottom line: does anyone have recommendations for a radial tyre on 16 inch/ 5 inch rims for a 1950s plus 4 ? I don't rally or race so ultimate performance is hardly an issue - good, safe performance is though.
Dave Blue 4/4 1969, Green +4 1953, (different) Green +8 1977
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
I have the same problem (here in the States) for my 1951 Plus 4.
Only expensive Radials. Bias Ply available at a significantly cheaper price. 100$ cheaper per tire. Internet searching reveals only Coker Tire.
I would go to the UK, and even pay shipping, if I could find a better solution.
I don't thrash the car so I guess I will have to go with Bias Ply. That's what is on there now and they have been ok, but . . .
Cheers, Mark
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Bottom line: does anyone have recommendations for a radial tyre on 16 inch/ 5 inch rims for a 1950s plus 4 ? I don't rally or race so ultimate performance is hardly an issue - good, safe performance is though. I would try Dougal or Tom at Longstone Tyres tel 01302 711123 https://www.longstonetyres.co.uk/I buy my Avon MTW tyres from them and they are very knowledgeable on the 'owd stuff & alternative specs
Thanks, I'll give them a ring - their website suggests Michelin XAS (but only 15 inch is available), and Pirelli Cinturato CA67, which are £430 - which seems a bit strong. But if it keeps me out of the ditch, then it could be money well spent. Many thanks.
Hmm, there's seems to be a potential problem with radials on 16 inch rims - as all they will fit the rim, the 'bulge' in the sidewall (ie the max width) of, say, the 185R16 radial may be too much - and thus will rub on the suspension.
Does anyone have a car on 16 inch rims, with a radial tyre fitted?
Posts: 987 Likes: 110
Posts: 987 Likes: 110 |
Why not just stick with the classic 5.00-16? The tires are affordable, stylish, and true to the original. https://www.grip500.de/reifen/5---1..._source=1&gad_campaignid=20985000123By the way, my 1946 Indian Chief also has 5.00-16 tires—motorcycle tires, of course. Avon. I’m very happy with them.
2003 Morgan 4/4 2-seater
I don't have a compelling reason if I'm honest - I just wanted to compare the same car using crossply vs radial.
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
I replaced the Excelsior 500 x 16 tyres on my +4 with 500/525 x 16 Pirelli Stella Bianca, from Longstone. They are fine but I did have a problem. The overall diameter is slightly larger which meant the spare didn't fit in cradle. Mine is a 4 seater so the spare sits vertically in the cradle and bolts onto a bracket on the rear. The added diameter pushed the wheel too high to allow the bolt to engage with the bracket. So I have an old. unworn, Excelsior spare wheel.
1956 Plus 4 4 seater
