Posts837,266
Posts: 5,432 Likes: 465
Posts: 5,432 Likes: 465 |
Thanks for jumping in Richard, as I typed previously, I may have access to a VPN available as part of my anti virus programmes options, though I have not ever made use of it, as I have never felt the need as I only really go on line via my own router at home all be it via WiFi.. Hmmm. Do you mind if I reset your password and try logging on as you from here? That way we can establish whether the issue lies with your ID on the image server or on some aspect of your computer setup? Tim, thanks. I note your list of possible sources for my issue, though it seems you missed my current lack of mental capability and level of frustration.... (-: I have also performed a quick scans via my anti virus software after each MSN update notification/request.. lest any such notification might be some sort of hacking attempt. I suspect timing of the issue may be related to the MSN updates which I have performed in the very recent past, and since I last posted in the gallery, which from a dead head was only a few days back..?
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I use an ipad for most things and a while back lost the TMImage access. Last week I restored a link. I did a safari search for it, opened it, saved a link in my "Car sites Favourites Group" I have set up to contain all car related web links. Open safari, select "TMImage" icon and straight to the login page. It opens from there. Safari currently uses DuckDuckGo search engine Earlier this year I did a clean of the laptop to get rid of clutter and built up cache junk etc. its an old-ish W10 and I got about 10GB of extra space on the C drive. I try keeping as much as possible in the D Drive to leave the C to run the laptop and not get filled up. I have two external hard drives for backing up. I am probably going to update the laptop later this year as the battery is ageing and extended W10 upgrades will stop. Do I go Apple or Windows? Undecided at the moment.
Circa 13:45hrs as the result of sospan`s post, I used Bing to find TM Image Library and logged on successfully.... ! (-: I then beamed up Talk Morgan, used the drop down Other Favourites on MSN Edge to click on TM image library and once again it opened without issue....Go figure as our American cousins might say..? (-:
Posts: 12,255 Likes: 317
Posts: 12,255 Likes: 317 |
Glad it's sorted. Maybe a cache issue then?
Glad it's sorted. Maybe a cache issue then? Thanks for your help Tim, as to whatever might have been the issue ..not got a clue. Deleted the cache using the two instruction sets which made no real change. tried to log on again first thing this morning... still a robot. Tried to log on around lunch time using sospan`s route via Bing as opposed through my favourites, and had no issues, followed up by logging on again this time via my favourites and no issues...? Typical digitisation issue, as to exactly that which the issue might have been, may well be anyone`s guess...? Unless someone knows different...
Posts: 6,954 Likes: 115
Posts: 6,954 Likes: 115 |
which from a dead head was only a few days back..? So, you like Gerry Garcia?
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
.............. Earlier this year I did a clean of the laptop to get rid of clutter and built up cache junk etc. its an old-ish W10 and I got about 10GB of extra space on the C drive. I try keeping as much as possible in the D Drive to leave the C to run the laptop and not get filled up. I have two external hard drives for backing up. I am probably going to update the laptop later this year as the battery is ageing and extended W10 upgrades will stop. Do I go Apple or Windows? Undecided at the moment. Replied in a new thread at https://www.talkmorgan.com/ubbthreads.php/topics/841798#Post841798
Thought to check if I might have still have access to the TM image galleries, and unfortunately it seems once again I have been excluded this time not as aa robot, which it seemed had been resolved for a few days though tried l this morning to be confronted by this message :-
Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 8.2.0". An error occurred while loading Chevereto.
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 8.2.0". An error occurred while loading Chevereto. I'm getting that message too.
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
