0 members (),
335
34
Topics49,841
Posts837,323
Posts: 873 Likes: 154
Posts: 873 Likes: 154 |
I made a quick stop at Morgan Belgium this afternoon to take a close look at the hood belt mounting brackets  I'm going to make these brackets myself, as they're quite simple  : ![[Linked Image]](https://zupimages.net/up/26/15/5ogs.jpg) ![[Linked Image]](https://zupimages.net/up/26/15/uxes.jpg)
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Here is my first version of the mounting bracket for the CX Bonnet Belt  : ![[Linked Image]](https://zupimages.net/up/26/16/evij.jpg) ![[Linked Image]](https://zupimages.net/up/26/16/6h7p.jpg)
Posts: 1,981 Likes: 103
Posts: 1,981 Likes: 103 |
Looking good. At the risk of stating the obvious, have you allowed for the thickness (maybe 3mm) of the material you are bending ?
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Regarding the 360-degree fold, I need to check with my factory to see if it's possible. I've already done it with 1.5 mm material, but I'm not 100% sure it would work with 3 mm...  Here's the prototype with a leather strap  : ![[Linked Image]](https://zupimages.net/up/26/16/v7yg.jpg)
As a model aeroplane enthusiast, I'd say that 1/8" balsa sheet would be a good step up from your thin cardboard prototype. You can allow for the thickness of the metal (or in my example, the balsa wood), the bends in the finished bracket will be radiused (not a sharp fold). That way you can check that everything is in the precise position you want it.
 : ![[Linked Image]](https://zupimages.net/up/26/16/drdq.jpeg)
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Great work as ever Nestor 😎🙏
