Posts837,264
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
Rich I don't have an iphone or other phone that can take photos. A photo from Dartmouth Castle last year was compressed - taken on an old Leica in portrait format. If taken in landscape format compression did not occur.
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Interesting Graham and a bit more information for our gallery chaps to go on.
Posts: 8,655 Likes: 407
Posts: 8,655 Likes: 407 |
I've suffered the distortion issue too
My cure was to very slightly edit the photo on the mobile (even just a tiny crop off one edge) and the image library reads it correctly Yes I've had the same issues and found the same cumbersome cure with portrait format photo's, and I've never used an iphone. It shouldn't happen though. ibb.com which I also use as a preference for picture hosting appears to use the same software format and doesn't cause this issue. tm-img admin please note.
Posts: 1,463 Likes: 98
Posts: 1,463 Likes: 98 |
Drove 95 miles on pretty boring roads to and from my closest dealer to get my agreed valuation form stamped. Lost £4K in 3 years, I’m fine with that. I was there no more than 10 mins! Pic just for interest as it was close by ![[Linked Image]](https://www.tm-img.com/images/2026/04/26/IMG_0469.md.jpeg)
Posts: 8,662 Likes: 487
Posts: 8,662 Likes: 487 |
My cure was to very slightly edit the photo on the mobile (even just a tiny crop off one edge) and the image library reads it correctly Yes I've had the same issues and found the same cumbersome cure with portrait format photo's, and I've never used an iphone. It shouldn't happen though. ibb.com which I also use as a preference for picture hosting appears to use the same software format and doesn't cause this issue. tm-img admin please note. Yep, I've got some tasty shots from Monaco to post here including a demo race of older generation F1 Ferraris but can't find the time to edit them yet, also tm-img won't let me create a new album
After some punishing roads driving through Holland, Belgium & France (and hitting a lorry strap) things felt a little 'off' After a through check over, found the SSL main springs must have sagged a little as the gap to the rebound was alarmingly large, so gaiters & dampers off and re-adjusted several times followed by the drop test, now sorted ![[Linked Image]](https://www.tm-img.com/images/2026/05/08/Rebound-spring.md.jpg) ps, this is pre clean up
Probably need to check mine again Jon. BTW looks you could benefit from some rebound spring gaiters. ![[Linked Image]](https://i.ibb.co/3m50GSfC/IMG-20240126-080620.jpg)
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
And the Wolf ones are the ones to get
Jon said he had removed his gaiters lads.
1 member likes this:
CooperMan |
Yes agreed, the Wolfies are the best & I have a pair in stock but can't be ar5ed with the amount of strip down to fit 'em - so the mohair hood material ones from Mr DW will go back on
I also like the ability to pop off the DW version for a clean and check-up at least once a year
1854sailor |
