9 members (Montegue, gmcn, hillclimber, MJF, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff),
298
82
Topics49,858
Posts837,463
Posts: 730 Likes: 58
Posts: 730 Likes: 58 |
TMers.
Having just watched Bangers and Cash reference the Plus 8 rebuild, one of the comments was that a plate should have been welded under the side light. Good idea, but instead of welding I was thinking of using a strong glue. You know the stuff that MMC use for clueing the chassis onto the cars today. Any idea of a good clue?
As normal, many thanks.
Navy Dave 1976 Morgan 4/4
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
I've used JB Weld Superweld Extreme for metal stuff - it's more like a superglue than the epoxy stuff
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
Don't know if they still make it but Araldite was the popular two pack epoxy for metals in my kit of travel spares
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Smack it under there with a layer of Soudal Carbond ... grips like a starving alligator but never fully hardens so won't crack.
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
On later superform wings the upper mount bracket is secured with six flush mount rivets in the area of the sidelight mounting. I would imagine slightly forward of bracket, shown looking from behind, to place it at highest point on wing. It could be this area is already reinforced. ![[Linked Image]](https://i.ibb.co/ZzTqGHvZ/IMG-20260602-083849.jpg)
Posts: 5,442 Likes: 468
Posts: 5,442 Likes: 468 |
Kevin, the chap who rebuilt what was to become my Trad +8 reinforced the underside of the hand formed alloy front wings, not only under the sidelight/stay mounting point, but glued rubber matting to the area where stones can hit hard enough to deform the alloy and cause star like cracking of the paintwork..
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
In the past, I have successfully used the lead replacement flashing stuff that roofers use around chimneys stick to the underside of wings to prevent stone rash and star cracks. Comes in a role from Jewsons.
1 member likes this:
Luddite |
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Metal bonding adhesive will be fine as long as you make sure the reinforcing piece follows the profile of the wing area you are strengthening as it retains an amount of flexibility, if not you could create a worse amount of point loading than the item being fixed. If you can't achieve this then JB weld would be a better choice as it will profile the reinforcing piece accurately to the area applied.
To all,
Many thanks for your replies.
