Posts837,961
Posts: 7,934 Likes: 133
Posts: 7,934 Likes: 133 |
Alright captains, skippers, pilots, pirates, helmsmen, etc, a water based vehicle question for you!
A good friend is looking at buying a used grp hull boat.
He has narrowed it down to a few options; however, both boats have not been removed from their fresh water moorings for a reasonably long period of time (one having spent the last six years in fresh water and the second, closer to nine, albeit it is currently out in dry dock).
My knowledge of boats is limited but I was always under the impression that a boat should be taken out of the water every 12-24 months to have the hull cleaned and a sacrificial antifouling paint applied? By not doing so, you run the risk of hull damage, osmosis, and general degradation. The longer the boat is in the water for, the greater the risk, because the hull doesn't have the opportunity to dry out.
Both boats have been kept on private moorings, hence not being removed, even for winters. One is a private sale and the other is with a broker, hence it now being out of the water. The broker is nonplussed that the boat was in the water for circa nine years and said a 'hull inspection' should allay any concerns.
This came up in a chat over the weekend, with said friend, and I was less convinced that a survey would be able to ascertain the full extent of any damage caused - my assumption being that it is non-invasive and therefore they will moisture test the hull, look for signs of osmosis and do a visual check; however, this isn't going to show internal damage to the layers of grp, is it?
Views and opinions of those far more knowledgeable in this area welcome! Is the non-removal from the water a 'walk away' or something that can be navigated around with a good inspection?
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
VV hard to comment without knowing the type of vessel , its hull layup and the temperature of the water where she lives. If when inspected out of the water there are no obvious blisters I would not be too concerned about the underlying laminate. An often overlooked area is has the bilge had water / diesel lying in it for any period ? His best bet is to try and talk to other owners of sisterships -that will often point the way for further investigation or if it is warranted.
99 plus 8 indigo
2 members like this:
Simon, Luddite |
Posts: 37,473 Likes: 988
Posts: 37,473 Likes: 988 |
Landlubber - there are plenty out there why take a risk ?
VV hard to comment without knowing the type of vessel , its hull layup and the temperature of the water where she lives. If when inspected out of the water there are no obvious blisters I would not be too concerned about the underlying laminate. An often overlooked area is has the bilge had water / diesel lying in it for any period ? His best bet is to try and talk to other owners of sisterships -that will often point the way for further investigation or if it is warranted. Thank you. What has surprised me is how similar to looking at old cars his experiences have been (which probably shouldn't have come as a surprise). So many boats described as cared for and cherished, obviously haven't been, and he's looked at more than a few where people couldn't even be bothered to give the boat a clean before he looked at it. One inspector he called has put the fear of god into him over osmosis in the hull; hence, it being a conversation point over the weekend catch-up. Landlubber - there are plenty out there why take a risk ? Argh! Mr Devonian pirate smuggler, I'm inclined to agree; however, as he is in-land, unless he's willing to pay for transport, there are less boats for sale than you'd imagine.
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Sacrificial anodes to protect external metal hull fittings and ablative anti-fouling paint are two separate but necessary things. A full survey on raised hull with moisture test meter some time after should reveal any nasties such as osmosis. The surveyor would typically give a list of any remedial work needed in his opinion as well which could be a useful bargaining chip.
